Monitoring bandwidth?
Is there a way to monitor bandwidth an IP or a set of IP's on an ASA firewall? I need to be see how much bandwidth certain applications are using through the ASA.
Re: Monitoring bandwidth?
I dont think you can do this with ASA.
Instead use tools like PRTG, etc.
MRTG can show me traffic on the interface...but I'm looking for traffic just to a particular set of IPs since we have a lot of connections going through the same ASA. I don't think MRTG gives you that granularity does it?
I suggest you give firewall analyzer a try.
http://manageengine.adventnet.com/products/firewall/
It comes with a 30 days trial .. license during which time you should be able to get the reports you are looking for.
I hope it helps .. please rate helpful posts
Hi, its not MRTG its PRTG.
PRTG does have the options.
http://www.paessler.com/prtg
174
