Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Monitoring IPSec Remote Access Users
Hi all,
please can any one help me to know about monitoring Remote access users using ASDM. As I have observed in ASDM, it is possible to monitor users currently logged in, but what I want to monitor is users who were logged in since the firewall started (for example, 30 days)..
Thank you,
Nagabhushan
2 ACCEPTED SOLUTIONS
Gold
Re: Monitoring IPSec Remote Access Users
you really need to use your logs for that.
Nagabhushan, I do agree with Steven , you would need to use/implement logging.
Yes you can
in ASDM goto
Home/Configuration/Monitor/VPN/Session
Since you don't have any permanent logging setup to send logs to a syslog server for that amount of time you have already lost that information from 30 days ago, you need to implement syslog .
Go over this link for monitoring, you can also filter syslog messages based on log ID number or logging severity levels
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/monitor.html
Gold
Yes you can
in ASDM goto
Silver
Syslog is the way to go. Just wanted to add something that will help on make syslog useful.
http://www.splunk.com
I use it for everything at home and work. There are free and enterprise versions.
Chad
Community Member
Thank you very much for your suggestion..
Nagabhushan
184
