Also as a little side note,
There is also difference in the ordering of the NAT configurations depending on the Section
- Section 1 and Section 3 Manual NAT rules are always gone through in the order you see them in the actual CLI configuration. So you might have 2 completely working rules BUT if they are in the wrong order it might be that other one of them is never used
- Section 2 Auto NAT rules are processed in an order that you dont usually decide yourself. The ASA puts them in order according to how they were configured.
So in a nutshell. You can manually set the order of the Manual NAT rules but Auto NAT rules are ordered automatically by the ASA itself.
You can see the current order of the Auto NAT rules with the command
show nat
- Jouni
