Multi context configuration on ASA
Dears
I am trying to configure multi context on the 5520 ASA , how can i configure 1 outside and 1 inside for the 2 context or how to configure both outside from the same subnet and insides also from the same subnet , i did the below configuration but didn't work :S
admin-context admin
context admin
  allocate-interface gi0/0 outside
  allocate-interface gi0/1 inside
  config-url disk0:/admin.cfg
interface gi0/0
interface gi0/1
interface gi0/2
interface gi0/2.12
vlan 212
interface gi0/2.13
vlan 213
interface gi0/3.14
vlan 214
interface gi0/3.15
vlan 215
context Context1
   allocate-interface gi0/2.12
   allocate-interface gi0/3.14
   config-url disk0:/Context1
context Context2
   allocate-interface gi0/2.13
   allocate-interface gi0/3.15
change context Context1
int gi0/1
ip address 10.10.10.10 255.255.255.0
change context Context2
int gi0/1
ip address 10.10.10.11 255.255.255.0
Friend, refer below document; this explains multiple context IP configuration.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808d2b63.shtml
Many thanks , i already checked it thanks for your help
Hall of Fame Super Silver
Typically you would allocate the physical interfaces to the admin context and then subinterfaces in the various other contexts.
Also, typically when you are using subinterfaces you do not assign an IP address to the parent interface as your downstream switch is expecting tagged traffic on the VLANs associated with the subinterfaces.
Have you had a look at this configuration guide?
Many thanks , yes i checked the mentioned configuration guide but didn't solve my problem , i can't assign 2 Vlans for out side (1 for context 1 and one for context 2 ) , i need to configure single inside and single outside for the system , then will allocate the sub interfaces as needed .
How can i achieve this??
366
