Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Multiple access-group on same interface?
Is there a way to configure multiple access-group on same interface on PIX?
such as:
access-group ACL-IN-1 in interface outside
access-group ACL-IN-2 in interface outside
TIA
Anonymous
N/A
Re: Multiple access-group on same interface?
No, you can only have one access-group assigned per interface.
No, this is not possible.
What are you trying to achieve ?
You might using object groups :
http://www.cisco.com/en/US/customer/products/hw/vpndevc/ps2030/products_tech_note09186a00800d641d.shtml
sincerely
Patrick
Not on PIX version 6, you can only apply one in an inbound direction. On version 7 PIX you should be able to apply one access list inbound and one access list outbound on the same interface in the same way you can on IOS.
Bronze
When asking questions, always specify which version of code you are using.
You can apply access-lists inbound and outbound on an interface in 7.x code. 6.x code only allows inbound.
In addition, you can also specify a service policy that can be applied either globally, or specifically to interfaces, and you can do things with the traffic there, as well.
Gave AndyR0binson some points because he was correct.
--Jason
Please rate this message if it solved some or all of your issue.
3576
