Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Multiple DMZ ASA help
We have ASA 5520 Cisco Adaptive Security Appliance Software Version 7.2(3).
Current Config for DMZ is :
interface GigabitEthernet0/2
nameif dmz
security-level 50
ip address x.x.x.1 255.255.255.0
I am using all the physical port & need to add another DMZ Segment. I am planning to configure following :
int gi0/2
no nameif dmz
no ip add x.x.x.1 255.255.255.0
int gi0/2.35
nameif dmz
vlan 35
security-level 50
int gi0/2.36
nameif dmz2
vlan 36
ip add y.y.y.1 255.255.255.0
I have few question regarding above configuration .
1 Am I on right path or not ?
2 When I will remove dmz from Physical interface to logical interface , what happen to my access-list associated with dmz interface ? do I need to recreate it or moving to logical interface will take care of the config automatically.
Thank you
Viral Patel
1 ACCEPTED SOLUTION
Community Member
Re: Multiple DMZ ASA help
I beleive you will have to recreate the access-group command to re-apply the access-list as the name removal will delete the associated access-group command.
Scott
Community Member
Scott
Community Member
I have currently this command applied to access-list dmz_inbound will apply to nameif interface dmz. I am assuming once I make above changes I may have to just reapply .
access-group dmz_inbound in interface dmz
Thank you
Viral Patel
269
