Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
My ASA 5520 route without setting up an exepmtion nat
I issue a clear configure all, setup the interfaces and with this minimal configuration, a PC conected to the DMZ interface, can contact the router on the outside.
The ASA routes ip and (this is a lab) cause the router has the ASA as defaut gateway, the packets return to DMZ host.
But there is no Nat Exemption in the configuration!! How can it work?
ASA5520-K8, Version 8.0(2)
1 ACCEPTED SOLUTION
Silver
Re: My ASA 5520 route without setting up an exepmtion nat
you need to read the documentation more
carefully. Starting with Pix 7.x and higher,
"no nat-control" is the default on pix
and ASA. Basically, the pix IS a router.
However, the basic principle still applies.
In other words, you still need ACL for low
to get to high.
CCIE Security
Silver
to get to high.
CCIE Security
Community Member
I read NAT chapter again and I found that. The ASA routes packets if no NAT roule is set for the interface.
"Interfaces at the same security level are not required to use NAT to communicate. However, if you configure dynamic NAT or PAT on a same security interface, then all traffic from the interface to a same security interface or an outside interface must match a NAT rule, as shown"
Cisco Security Appliance Command Line
Configuration Guide--
Thanks!
244
