Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Nat-C not happening from DMZ to Inside
I was trying to perform NAT-C on ASA 8.2. The setup was pretty simple. I had an Inside (Security-Level 100) interface, DMZ (Security-Level 50) and an Outside Interface (Security-Level 0).
I wanted to perform Nat from DMZ hosts to Inside hosts. When I used "nat" & "global" commands, it didn't work (all required ACLs were in place).
Is it something like NAT-C wont happen for lower security level to higher security level if we use nat & global statements (I know, static statement works in this case but I want to know about nat & global)
Everyone's tags (3)
Silver
NAT control requires that
NAT control requires that packets traversing from an inside interface to an outside interface match a NAT rule; for any host on the inside network to access a host on the outside network, you must configure NAT to translate the inside host address. NAT-C will not work when traffic coming from lower security level going towards higher security level.
Community Member
Thanks, is there any
yes
Thanks, is there any particular reason for "NAT-C will not work when traffic coming from lower security level going towards higher security level." or this is the way its developed ?
And can you please refer to any such link/article/book where this statement resides ?
Silver
Reference: http://www.cisco
Reference: http://www.cisco.com/c/en/us/td/docs/security/asa/asa82/configuration/guide/config/nat_control.html
"Please rate helpful posts"
26
