NAT command conversion PIX 6.3 > 8.4(2)
I am in the process of migrating a production firewall from PIX 6.3 to ASA 8.4(2). This is going to be a complete firewall rebuild and I will not be upgrading the configs because they have become out of date and very bloated. I am in the process of converting the NAT commands and I was hoping somebody could verify my conversions. Please see the old and new commands below.
-----------OLD Commands-----------
global (outside) 1 interface
global (intApps) 2 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 2 10.1.1.233 255.255.255.255 0 0
nat (inside) 0 0.0.0.0 0.0.0.0 0 0
static (inside,intApps) 10.1.2.0 10.1.2.0 netmask 255.255.255.0 0 0
static (inside,intApps) 10.1.3.0 10.1.3.0 netmask 255.255.255.0 0 0
static (inside,intApps) 10.1.4.0 10.1.4.0 netmask 255.255.255.0 0 0
static (inside,intApps) 172.1.1.176 10.1.5.176 netmask 255.255.255.240 0 0
static (inside,intApps) 172.1.2.176 10.1.6.176 netmask 255.255.255.240 0
---------------------------------NEW Commands-------------------------------------------------
object network host_1
        host 10.1.1.233
nat (inside,intapps) dynamic interface
object network NAT-Range-Network_1
        subnet 172.1.1.177 172.1.1.190
object network Network_1
        subnet 10.1.5.176 255.255.255.240
nat (inside,intapps) static NAT-Range-Network_1
object network NAT-Range-Network_2
        subnet 172.1.2.177 172.1.2.190
object network Network_2
        subnet 10.1.6.176 255.255.255.240
nat (inside,intapps) static NAT-Range-Network_2
I am hoping these commands would be enough to replicate the previous functionality. I removed all the static identity NATs because NAT control is no longer in place so those rules are not required. Additionally I didn't re-create the rules that had NAT ID 0 or 1 because it didn't look like they were doing anything.
Also can someone please let me know if that is the correct way to do the static NAT commands at the bottom.
Please let me know if this configuration will work or where I need to correct some things.
Thanks!
1 ACCEPTED SOLUTION
This will not work:
You got to use a netmask, the subnet keyword is to define as it name says a subnet not a range of ip addresses, so you need to change that, besides that everything is okay.
Regarding the static question, yes. That is how you do it!
Do rate helpful posts,
Julio
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
This will not work:
Julio
O haha thats embarassing I actually had the netmask created properly in my config. Although I initially had the range command here because I had initially created the NAT command as dynamic instead of static and I updated the range command to subnet but forgot to do the mask :/
Just to verify if I update the mask properly these NAT commands should work identically to the other commands and nothing else is needed to replicate the previous NAT implementation?
Thanks!
That is correct, that is all you need and you will be ready,
Please mark the question as answered unless you have other question, I will be more than glad to help.
Julio
950
