NAT destination on an interface of a CISCO ASA 8.3
Hi all,
I have a ASA firewall, version 8.3.
This firewall is connected with 2 interfaces, one for the LAN (let's say that the IP address is 192.168.10.254), and one for the WAN (let's say 10.10.10.254)
Is it possible to configure that kind of NAT:
IP Source                                                            IP destination                                                      Port
192.168.10.0 / 24 (a host on the LAN)         -->      192.168.10.254(LAN interface of the FW)               X
becomes:
10.10.10.254 (WAN interface of the FW)       -->        15.10.10.254                                                    Y
(and the IP address 15.10.10.254 will be routed with a static route on the FW)
I wonder if this kinf of NAT is supported on the CISCO ASA FW. I know that it's possible on Juniper FW but not the ASA ones...
Many thanks for your help,
1 ACCEPTED SOLUTION
Super Bronze
Re: NAT destination on an interface of a CISCO ASA 8.3
OK, you can possibly configure the following:
object network obj-192.168.10.0
     subnet 192.168.10.0 255.255.255.0
object network obj-15.10.10.254
     host 15.10.10.254
object network obj-192.168.10.1
     host 192.168.10.1
nat (inside,outside) source dynamic obj-192.168.10.0 interface destination static obj-15.10.10.254 obj-192.168.10.1
For the destination address of 15.10.10.254, you can't NAT it to the inside interface ip address, however, you can NAT it to a unique ip address within the 192.168.10.0/24 subnet.
Hope that makes sense.
Super Bronze
Sorry, I am a bit confused with the IP Source and IP Destination that you posted:
Do you mean to say the following:
192.168.10.0 / 24 (a host on the LAN)         -->      15.10.10.254                 X
becomes:
If the above is correct, then do you mean to try:
- to NAT all IP address from 192.168.10.0/24 destined to 15.10.10.254 to 10.10.10.254?
OR/
You actually wants to NAT both source and destination as follows:
NAT: 192.168.10.0/24 destined to 15.10.10.254 to 10.10.10.254
and also,
NAT: 15.10.10.254 to 192.168.10.254?
Hello Jennifer,
It's actually the second case: I want to NAT both:
the destination address (before NAT, it's the IP address of the LAN interface of the FW - 192.168.10.254 / after NAT, it's the address 15.10.10.254)
the source address (before NAT, it's an IP on the LAN range / after NAT, it's the adress of the WAN interface of the FW).
For the NAT of the source (the second one), i think it's possible, it's just a PAT.
But i'm not sure with the other one...
Super Bronze
     host 15.10.10.254
     host 192.168.10.1
It does make sense.
If I can't chose the interface as the nat address, and I have to choose another one in the LAN range (in your example, 192.168.10.1), how are the flows being routed to the Firewall? With the Proxy-ARP activated on the LAN interface, am I right?
Super Bronze
Absolutely correct, proxyarp needs to be enabled on LAN interface:
no sysopt noproxyarp inside
Ok, many thanks for your help and quick answers!
400
