NAT help
I have a cisco ASA 5520 and connected as a trunk I have a Cisco 3750 with a VLAN for our WAN office.
This remote WAN office has a router which uses DHCP relay back to our LAN where the ASA is, we don't manage the router and have to pay money for any change (silly or what).
ANyway I need to change the DHCP server they point to and thought I Could NAT the one the point to now to the new one, is this possibe?
I did try add a NAT what it didn't work.
Re: NAT help
if the relay configuration on the router is pointing to the real ip-address of your DHCP server - Natting will not help.
a rough diagram would be helpful to understand your requirement.
-Vikram
Re: NAT help
"if the relay configuration on the router is pointing to the real ip-address of your DHCP server - Natting will not help. "
This is exactly what I'm doing.
I will try and get a diag done. Basically:
LAN
ASA - 3750-(VLAN7) - Remote WAN
Router
Internet
Re: NAT help
Well then you will have to pay do get the change done on router this time.
Re: NAT help
fair enough
114
