Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
NAT Help
Hi –
I just wanted to verify my config and make sure I’m doing this correctly.
I’m setting up a new ASA VPN firewall for all our vendor site-to-site connections. I don’t want to expose my inside subnets to the vendors so I was going to carve out subnets from a 10.3.0.0/16 space to NAT the traffic.
Example:
Vendor X subnet
Object network VEND_X_VPN
192.168.1.0 /24
My Internal subnet for vendor X to connect to”
Object network MY_VPN
10.1.60.0/24
Object network VEND_NAT
network 10.3.1.0 255.255.255.0
NAT Statement – this would be applied on my firewall so I’m assuming the Vendor will put the NAT’d address (10.3.1.0/24)in his crypto map to connect to.
nat (inside,outside) source dynamic object-group MY_VPN obj-VEND_NAT destination static VEND_X_VPN VEND_X_VPN
Does this look right?
Mike
1 ACCEPTED SOLUTION
Silver
NAT Help
On your local VPN math address ACL you need to put the 10.3.1.0/24
Value our effort and rate the assistance!
Silver
NAT Help
Just change it to source static:
nat (inside,outside) source static object-group MY_VPN obj-VEND_NAT destination static VEND_X_VPN VEND_X_VPN
The VPN portion is correct.
Silver
NAT Help
Silver
NAT Help
If you have any doubts please let me know.
Please mark as answered and rate the assistance.
NAT Help
Thanks Jumora!
So basically my crypto map ACL will look like:
ACL crypto 1 permit my_vpn vend_nat
So I dint need to reference the vendors 192 subnet because the inside interface is doing the NATing correct?
Mike
Silver
NAT Help
Ok wait, from what I understood what you were doing was NATTING your local network so that the remote VPN network would not know of your real network 10.1.60.0/24 so you were going to translate it to 10.3.1.0/24 when going to
192.168.1.0 /24. If this was the case the NAT rule that I going to place under this conversation is correct:
Then what you need to add on the match address ACL would be somehting like this:
access-list VPN permit ip 10.3.1.0 255.255.255.0 192.168.1.0  255.255.255.0
That is what I was saying.
151
