Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
nat (inside,outside) static 200.x.x.x
Hi Everyone,
Say we have webserver which has internal IP of 172.16.10.10
If we need outside users from internet who need to access the webserver on IP say  200.x.x.x
We can config the NAT as below also
Mahesh
2 ACCEPTED SOLUTIONS
Super Bronze
Hi Mahesh,
I would usually configure a normal Static NAT as Network Object NAT
You first configure a "object network " under which you configure the source IP for the NAT configuration with the "host" command. Finally you enter the "nat" command inside/under the "object network ".
object network STATIC
host 172.16.10.10
Depending on how the rest of the NAT configuration is built, some other NAT rule might override this but personally I have not had problem with configuring Static NAT this way.
You also have an option to configure the NAT in the following way
object network SERVER-REAL
host 172.16.10.10
object network SERVER-MAPPED
host 200.x.x.x
nat (inside,outside) source static SERVER-REAL SERVER-MAPPED
As you can see the difference from the first way I mentioned is the fact that we use Manual NAT / Twice NAT to configure this Static NAT. We create 2 "object network " which define the real and the mapped IP address. We then use those objects in the actual "nat" configuration.
The difference with the above 2 NAT configurations is that the Network Object NAT s on lower priorty in the ASA NAT rules compared to the above Manual NAT.
- Jouni
Super Bronze
I guess those are the terms/names the ASA itself uses when you use the "show nat" or "show nat detail" commands
So yes, the first one is a Auto NAT example and the second one is a Manual NAT example.
Both achieve the same but the Manual NAT is higher priority NAT rule than the Auto NAT rule.
I have personally gotten used to calling them Network Object NAT and Manual NAT/Twice NAT.
- Jouni
Super Bronze
Hi Mahesh,
host 172.16.10.10
host 172.16.10.10
host 200.x.x.x
- Jouni
Hi jouni,
So first example was of Auto NAT  and second was Manual NAT  Right?
MAhesh
Super Bronze
- Jouni
MAny  thanks Jouni Again.
LEarning ASA  world bit by bit woth your help and this forum.
Best regards
MAhesh
352
