NAT (INSIDE To OUTSIDE)
I need Configuration of this topology
At Outside Router
int f0/0
ip add 10.1.1.2 255.255.255.0
At Inside Router
int f0/0
ip add 192.168.1.2 255.255.255.0
At ASA
int e0
ip add 10.1.1.1 255.255.255.0
int e1
ip add 192.168.1.1 255.255.255.0
I want NAT from inside to outside and also need ACL configuration and attached diagram.
and version of ASA is 8.2
Navaz
Message was edited by: Navaz Wattoo
Navaz
1 ACCEPTED SOLUTION
Re: NAT (INSIDE To OUTSIDE)
static (inside,outside) 10.1.1.1 192.168.1.1 netmask 255.255.255.255
access-group OUT in interface outside
Remove above 2 commands and yes it will work .
Cheers
Pankaj
Remember to rate helpful answers.
Static NAT
Nat (inside,outside) 10.1.1.1 192.168.1.1.
Dynamic NAT
nat ( inside) 1 192.168.1.0 255.255.255.0
global (outside) 1 interface --------------- (PAT)
or
global (outside) 1 10.1.1.1-252 (its depend on your subnet as your /24 in betwen router and firewall)
global (outside) 1 10.1.1.254
ACL requirement depends on your requirement , what exactly you want to achieve, although in this case traffice will traverse from higher to lower so you do not need ACL here.
If you to access from outside to inside ACL would be
access-list Outside_in extended permit tcp any
access-group Outside_in in interface outside.
Pankaj
i need packets from inside to outside
Navaz
Navaz
although in this case traffice will traverse from higher to lower so you do not need an ACL here.
Cisco ASA by deault allow your inside traffic to Outside if your configuration is proper.
Do remember to rate helpful post.
Cheers!!
Pankaj
with this confiugration can i send packets from inside to outside?
Navaz
Navaz
THIS MY ASA CONFIGURATION
ciscoasa(config)# sh running-config
: Saved
ASA Version 8.0(2)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 10.1.1.1 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/4
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/5
shutdown
no nameif
no security-level
no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
access-list OUT extended permit tcp any any
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat-control
nat (inside) 1 192.168.1.0 255.255.255.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
prompt hostname context
Cryptochecksum:00000000000000000000000000000000
: end
ciscoasa(config)#
THIS MY OUTSIDE ROUTER CONFIGURATION
R1(config)#do sh run
Building configuration...
Current configuration : 877 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
ip domain name lab.local
interface FastEthernet0/0
ip address 10.1.1.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip route 192.168.1.0 255.255.255.0 10.1.1.1
no ip http server
no ip http secure-server
logging alarm informational
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R1(config)#
THIS MY INSIDE ROUTER CONFIGURATION
R2(config)#do sh run
Current configuration : 880 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip route 10.1.1.0 255.255.255.0 192.168.1.1
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2(config)#
Navaz
Navaz
Cheers
Pankaj
Thanks a lot
Navaz
Navaz
277
