NAT issue that just won't die
I figured i'd start a new thread since this original problem dates back some time.  part of the problem was security levels were used initially way back when instead of interface acl's so i have these recurring nat issues, which i've just about resolved.
My problem now is really with 2 interfaces, Ex, and LV.  Right now i can get to devices on the Ex interface (192.168.180.x) from LV.  And i can get to devices on the LV interface (192.168.139.x) from the Ex interface.
I need to lock down traffic ONLY from LV->Ex to three specific IP's and a range of ports.  I have the object groups for both the ip's and ports:
object-group network ExchangeInternal
network-object host 192.168.180.11
network-object host 192.168.180.12
network-object host 192.168.180.25
object-group service Exchange_Services tcp
port-object eq 26
port-object eq 587
port-object eq 993
port-object eq 995
port-object eq www
port-object eq https
port-object eq imap4
port-object eq pop3
port-object eq smtp
Here's what i did:
access-list Exchange-In extended permit tcp 192.168.139.0 255.255.255.0 object-group ExchangeInternal object-group Exchange_Services
access-group Exchange-In in interface Ex
I had a limited window to do this so.....
The two addresses i was using to test behind each interface were (Ex) 192.168.180.25 and (LV) 192.168.139.7, and before any changes i could ping each way and get replies.  After adding the two lines above:
From 192.168.139.7 a ping to 192.168.180.25 kept working as expected.
A ping from 192.168.180.25 to 192.168.139.7 stopped working.
The only other thing i could do in the time frame was packet tracers, so i have that as well showing the failures if needed.
I guess my first question, on applying an interface acl IN the Ex interface, what am i missing that Out traffic stopped?
Thank you..
1 ACCEPTED SOLUTION
Super Bronze
Re: NAT issue that just won't die
Argh, my head hurts well mostly because of not eaten anything yet and trying to look at configurations.
So lets start from beginning
You have the following interfaces which are directly connected to their networks
interface GigabitEthernet0/3.139
vlan 139
nameif lv
security-level 90
ip address 192.168.139.1 255.255.255.0 standby 192.168.139.2
interface GigabitEthernet0/3.180
vlan 180
nameif Ex
security-level 90
ip address 192.168.180.1 255.255.255.0 standby 192.168.180.2
You say above that you want to limit traffic from network 192.168.139.0/24 to network 192.168.180.0/24 to only specific destination hosts and services.
So naturally the place where we control that traffic is where its sourced from. Network 192.168.139.0/24 according to the above interface configuration is located on interface "lv" and NOT interface "Ex"
So we need an inbound ACL on the interface "lv" to control so that network 192.168.139.0/24 can only access certain hosts and services on the network 192.168.180.0/24 which is located on the interface "Ex"
If we further presume that
  • Interface "lv" had no ACL prior to this
  • Traffic rules should be allowed to everywhere else
Then you need to configure something like this
access-list LV-IN remark Allow traffic to certain Ex hosts
access-list LV-IN permit tcp 192.168.139.0 255.255.255.0 object-group ExchangeInternal object-group Exchange_Services
access-list LV-IN remark Deny All Other traffic to network Ex
access-list LV-IN deny ip 192.168.139.0 255.255.255.0 192.168.180.0 255.255.255.0
access-list LV-IN remark Allow all other traffic
access-list LV-IN permit ip 192.168.139.0 255.255.255.0 any
access-group LV-IN in interface lv
Though since you have to this day only used the "security-level" value to determine where the "lv" network can connect to, you might need to add some "deny" statements before the rule that allows all other traffic.
- Jouni
Super Bronze
I am not sure if that is the only ACL rule in the ACL that is applied to the interface "Ex"? I would presume that its not?
If it is, then it would mean that only that traffic is allowed and rest traffic is blocked because of the implicit Deny All in the end of all interface ACLs.
To my understanding if you have "inspect icmp" and "inspect icmp error" enabled on the firewall then those ICMP return messages would be allowed back automatically.
If this is not the case then I guess you could try adding this ACL rule to the "Ex" interfaces ACL
access-list Exchange-In permit icmp 192.168.139.0 255.255.255.0 object-group ExchangeInternal echo-reply
And see if that helps at all.
Naturally if none of the above were the case then it would probably help seeing the output of those "packet-tracer" commands you used.
- Jouni
No it is the only interface acl applied...the initial issue was i only had one way communication between the interfaces due to security levels.  Now they both have theirs set to 90 (dont ask) but nothing is at 100
Here's the relevant config.  With this i can pass traffic bidirectional across the two interfaces.  All my servers on 180 can see my servers on 139 and back.  Which is good, but it's wide open.
vlan 139
nameif lv
security-level 90
vlan 180
nameif Ex
security-level 90
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
static (Ex,lv) 192.168.180.0 192.168.180.0 netmask 255.255.255.0
static (lv,Ex) 192.168.139.0 192.168.139.0 netmask 255.255.255.0
policy-map global_policy
class inspection_default
  inspect dns preset_dns_map
  inspect ftp
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect xdmcp
  inspect pptp
  inspect ipsec-pass-thru
  inspect icmp
  inspect h323 h225
  inspect h323 ras
service-policy global_policy global
Since this is wide open i thought i could add the follwing to restrict traffic to the defined (exchange) ports and addresses from 139>180:
Prior to the above two lines, packet tracer shows the following as allowed.  When i apply the acl i get this instead (let me know if you need to see the working as well):
packet-tracer input Ex tcp 192.168.180.25 32000 192.168.139.7 25
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xac7a7eb0, priority=1, domain=permit, deny=false
hits=1775854009, user_data=0x0, cs_id=0x0, l3_type=0x8
src mac=0000.0000.0000, mask=0000.0000.0000
dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
  match ip lv 192.168.139.0 255.255.255.0 Ex any
    static translation to 192.168.139.0
    translate_hits = 106535, untranslate_hits = 6
NAT divert to egress interface lv
Untranslate 192.168.139.0/0 to 192.168.139.0/0 using netmask 255.255.255.0
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0xace27010, priority=11, domain=permit, deny=true
hits=139, user_data=0x5, cs_id=0x0, flags=0x0, protocol=0
src ip=0.0.0.0, mask=0.0.0.0, port=0
dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Result:
input-interface: Ex
input-status: up
input-line-status: up
output-interface: lv
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
here it is working, without the acl applied:
packet-tracer input ex tcp 192.168.180.25 32000 192.168.139.7 25
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
    translate_hits = 120755, untranslate_hits = 12722
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: FOVER
Subtype: standby-update
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
  match ip Ex 192.168.180.0 255.255.255.0 lv any
    static translation to 192.168.180.0
    translate_hits = 12807, untranslate_hits = 164561
Static translate 192.168.180.0/0 to 192.168.180.0/0 using netmask 255.255.255.0
Phase: 8
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
static (Ex,outside) tcp 7.x.x.207 www 192.168.180.25 www netmask 255.255.255.255
  match tcp Ex host 192.168.180.25 eq 80 outside any
    static translation to 7.x.x.207/80
    translate_hits = 131, untranslate_hits = 5927
Phase: 9
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
    translate_hits = 120757, untranslate_hits = 12724
Phase: 10
Type: NAT
Result: ALLOW
Config:
static (lv,dmz) 192.168.139.0 192.168.139.0 netmask 255.255.255.0
  match ip lv 192.168.139.0 255.255.255.0 dmz any
    translate_hits = 5296, untranslate_hits = 9332
Phase: 11
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 12
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 583591158, packet dispatched to next module
Phase: 13
Type: ROUTE-LOOKUP
Subtype: output and adjacency
Result: ALLOW
Config:
found next-hop 192.168.139.7 using egress ifc lv
adjacency Active
next-hop mac address 0050.568a.3c77 hits 150
Result:
input-interface: Ex
input-status: up
output-status: up
Action: allow
Super Bronze
Correct if I am wrong but to me it seems that you have applied an ACL to the "Ex" interface which source address belong to the "Lv".
vlan 180
nameif Ex
security-level 90
So the source address will never be from 192.168.139.0/24 since the "Ex" network is 192.168.180.0/24
So it seems to me that you have to switch the source and destiantion network in the ACL.
But also I am wondering if the above is truly the COMPLETE ACL then that would mean that all outbound traffic from behind "Ex" would be denied. Actually at the moment it should be as the only permit rule is using wrong source network.
- Jouni
Wait a second, did i get all twisted up?
"But also I am wondering if the above is truly the COMPLETE ACL then that would mean that all outbound traffic from behind "Ex" would be denied."
-this is in fact what happened.
I'm trying to restrict traffic originating from 192.168.139.0 to 192.168.180.0, so that the 139 network can only get to 3 ip addresses (and specified ports as well) on the 180 network.  WITHOUT affecting traffic outbound from 180.
Doesn't that make the source 192.168.139.0/24?
In the broad view, an Exchange server at 192.168.139.7 needs to be able to communicate with the multiple servers at 192.168.180.0/24.  Communication out from 192.168.180.0/24 should be allowed in it's entirety.
Super Bronze
vlan 139
nameif lv
security-level 90
vlan 180
nameif Ex
security-level 90
- Jouni
I was all twisted up, because i was looking at it inbound to EV, it needed to be ON the ev interface...not the source interface.  ugggh.
as always, thanks.
I'll post back the results after I can do the config after hours, but looking at it, i'm quite sure this is correct
Thanks.
Super Bronze
I managed to almost miss the most important rule in the above ACL. This is to block all other traffic to the network 192.168.180.0/24 from the network 192.168.139.0/24
I edited it to my above reply with RED
- Jouni
Hahahaha i was just about to ask after looking at it for several more minutes...
100% dead on the money!
Now to wrap my head around why this worked IN interface lv.  Lv is the source, ex the destination so the flow of traffic is lv>ex which implies out.  Now my head hurts.
I tested access-group LV-IN out interface lv, lv to ex remained unchanged and i could still ping addresses on 192.168.180.0/24 from 139.0.  But i could no longer go the reverse   Not good in either case.
Regardless of me grasping it for now, it's up and working and i'm very appreciative!  Thanks.
Super Bronze
I remember wondering the same thing when I first started configuring some ACLs on routers and firewalls.
The direction in which the ACL is attached to an interface can be a bit missleading.
You will be always thinking the direction from the perspective of that single interface. When a user behind an interface initiates a connection and sends the first packet, in what direction does that traffic flow? It will naturally be "in" / Inbound traffic to the interface.
An "out" / Outbound ACL would be used to control traffic that is leaving an interface towards whatever is behind that interface.
I personally use only "in" / Inbound ACLs (and I would imagine majority of users do) on the ASA interfaces. These inbound ACLs will then control all the connection forming and traffic from behind those interfaces.
- Jouni
You need to write an ASA book.
Thank you.
213
