Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
NAT issue
I am having problems getting a server on the inside of my network to be seen as a specific IP to the world.
The inside server is 10.99.99.61
The outside address should be 172.16.199.206
The global address for the PIX is 172.16.199.194
What statements should I have in place to make it map correctly?
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: NAT issue
Joe
Can you remove
nat (inside) 3 10.99.99.61 255.255.255.255
global (outside) 3 172.16.199.206 255.255.255.255
and in it's place put
static (inside,outside) 172.16.199.206 10.99.99.61 netmask 255.255.255.255
you may also need to clear the xlate for this entry.
It's not clear from your config but what does access-list allownat do. It may be that this NAT takes effect before your nat 3 statement.
You haven't got any entries for .206 in your acl, are you going to add them.
Generally speaking servers that you want to present to the outside should use static (inside,outside) ... statements rather than nat/global statements. Nat/global statements are more commonly used for dynamic NAT.
Jon
Re: NAT issue
Joe
then you will need to add into your acl on the outside interface
access-list outside_in permit tcp any host 172.16.199.206 eq www
Note - i have given an example using http. you can modify to match what you want to allow.
Edit - if you don't already have an acl on the outside interface you will need to apply the acl from above
access-group outside_in in interface outside
Be aware that there is an implicit "deny ip any any" at the end of any access-list.
Jon
Community Member
Re: NAT issue
Jon,
Sorry I was a little to vague.
Here is an example of the config that I currently have in place that does not work correctly:
access-list inbound2 extended permit tcp 192.168.3.0 255.255.255.0 host 172.16.199.207 eq smtp
access-list inbound2 extended permit tcp 192.168.209.64 255.255.255.192 host 172.16.199.207 eq smtp
access-list inbound2 extended permit tcp 192.168.3.0 255.255.255.0 host 172.16.199.208 eq smtp
access-list inbound2 extended permit tcp 192.168.209.64 255.255.255.192 host 172.16.199.208 eq smtp
access-group inbound2 in interface outside
global (outside) 2 interface
global (outside) 1 172.16.199.202
nat (inside) 0 access-list nonat
nat (inside) 2 access-list allownat
nat (inside) 1 10.99.99.33 255.255.255.255
static (inside,outside) tcp 172.16.199.207 smtp 10.99.99.61 smtp netmask 255.255.255.255
static (inside,outside) tcp 172.16.199.208 smtp 10.99.99.33 smtp netmask 255.255.255.255
The IP of the "interface" is 172.16.199.194
Whenever I check to see what IP I am showing to the world as on the 10.99.99.61 server it always comes back to 172.16.199.194 but I want it to be 172.16.199.206.
But I do not want to change what the rest of the clients going out to the world are seen as which should stay 172.16.199.194.
Joe
Re: NAT issue
Joe
Can you remove
Jon
Community Member
Re: NAT issue
Jon,
Thanks for the assistance.
Removing the nat (inside) statement for that specific server worked.
My only concern is that I have other static entries for that server so when I inserted the
entry i recieved a warning regarding their already being static entries, although it still inserted the line and works as expected.
Joe
Re: NAT issue
Joe
You should be alright because you are using a different public IP in your other static statement ie.
you may want to check that your smtp still works but it should be fine.
What you could do if you get problems is map the specific ports as you have done with the static statement above rather than just all ports eg.
static (inside,outside) tcp 172.16.199.206 www 10.99.99.61 www
but it does depend how many ports you are allowing through to that server.
Glad you got it working and appreciate the rating.
Jon
129
