Nat or ACL Problem?
New ASA5505 configured with ASDM. Tried to get the config running on 8.03 and the current 7.23.
What I want to do is setup a list of our Static IP's and allow only them to access a Terminal Server using only the TS ports specified in a TCP Service Group. The config I have looks very much like the config I have in another ASA5510 which is working fine.
When I try to connect from the defined static IP static1 via the RDP client I can see it being block in the syslog.
Deny tcp src outside:static1/31856 dst inside:xxx.xxx.xx.xxx/3389 by access-group "outside_access_in" [0x0, 0x0]
I am at a loss as I think I have the Static NAT and ACL correct.
Thanks for any help
Brad
ASA5505 Config:
: Saved
ASA Version 7.2(3)
hostname ciscoasa
domain-name default.domain.invalid
enable password xxx
names
name 208.x.x.111 static1
name 192.168.1.25 temptermserv
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.222 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
boot system disk0:/asa723-k8
ftp mode passive
dns server-group DefaultDNS
object-group network YPMStatics
network-object host static1
object-group service termservports tcp
port-object range 3389 3389
port-object range www www
port-object eq citrix-ica
access-list outside_access_in extended permit tcp object-group YPMStatics object-group termservports host temptermserv object-group termservports
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) interface temptermserv netmask 255.255.255.255
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.100-192.168.1.200 inside
dhcpd dns 198.161.156.1 207.194.28.230 interface inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
1 ACCEPTED SOLUTION
Re: Nat or ACL Problem?
Ah sorry Brad, my bad. Do this
access-list outside_access_in extended permit tcp object-group YPMStatics interface outside object-group termservports
Hi Brad
In your ACL, you permit YPMStatics hosts to establish connection from termservports to host temptermserv on termservports. But from port is a randomly created port so you shouldnt specify it in ths case. Do the following modification
no access-list outside_access_in extended permit tcp object-group YPMStatics object-group termservports host temptermserv object-group termservports
access-list outside_access_in extended permit tcp object-group YPMStatics host temptermserv object-group termservports
I did make the change (had it this way when I tried the 8.0.3 image).
It now says:
But I still get the syslog error
Deny tcp .... by access-group "outside_access_in"
Thanks for the help.
Brad
Thanks husycisco, that worked like a charm I can get some sleep tonight.
Cheers!
Brad
132
