NAT outside to inside and inside to outside (in 8.4(2) version)
Thanks a lot and i attached a diagram here
Requirement:
need to pass through traffic from outside to inside and inside to outside.
I also attached a diagram with the ip
and also tell me one thing that natting is only for private to public or public to private.
Navaz
  • Firewalling
Hi,I think i replied on your
I think i replied on your post earlier as well.
As per your query , you can NAT any kinds of IP(Public or Private) into any kind((Public or Private)).
For Bidirectional traffic , you always need static NAT
When you want Uni Directional Traffic , you can use Dynamic NAT/PAT.
For the Inside to Outside Traffic , you can use this NAT:-
object network LAN
subnet 0 0
nat (inside,outside) dynamic interface
FOr Outside to Inside Traffic , you would only want access for certain Servers. Just like Internally hosted Web Servers
For this , you can either use , Static PAT/NAT:-
object network host
host 10.10.10.10
nat (inside,Outside) static interface service tcp 3389 3389
access-list outside_inside permit tcp any host 10.10.10.10 eq 3389
This will enable you to take the RDP access for your PC from the internet.
Is this what you want ?
Thanks and Regards,
Vibhor Amrodia
Thanks VibhorAttached updated
Thanks Vibhor
Attached updated diagram
1. In this diagram dmz server having ip 10.1.1.103/24 is the proxy server for the internet on LAN users and i need only https or http trafice allow from the dmz server.
2. For outlook of the lan user need to allow from inside to outside only microsoft outlook traffice.
and ASA Version 8.2(5)
These two are the requirement.
Navaz
Hi,As per your requirements:
As per your requirements:-
1) You can restrict the traffic using the interface ACL's and only allow 80 and 443 traffic through the ASA device. This you can apply on the DMZ interface.
2) For this , i think you might need to port forward 443 and 25 Port from the Public IP to the Microsoft Server or you can also apply a one-one NAT on the ASA device and allow the ACL on the outside interface.
Let me know if you have any other queries.
Thanks and Regards,
Vibhor Amrodia
Please define the
Please define the configuration of these two points.
Navaz
Hi,1) access-list DMZ-To
1) access-list DMZ-To-outside permit tcp any any eq 80
access-list DMZ-To-outside permit tcp any any eq 443
access-list DMZ-To-outside deny ip any any
2) object network Outlook
host <Private IP>
nat (inside,outside) static interface service tcp 25 25
object network Outlook-Https
host <Private IP>
nat (inside,outside) static interface service tcp 443 443
Thanks and Regards,
Vibhor Amrodia
It gives error ACTIVE(config)
It gives error
ACTIVE(config)# host 172.16.20.42
ERROR: Invalid hostname: '172.16.20.42'
INFO: A hostname must start and end with a letter or digit, and have as interior characters only letters, digits, or a hyphen.
ACTIVE(config)#
Navaz
Hi,You don't have to exit out
You don't have to exit out of the object sub configuration.
ACTIVE(config-obj)# host 172.16.20.42
ACTIVE(config-obj)# nat (inside,outside) static interface service tcp 443 443
Thanks and Regards,
Vibhor Amrodia
Now got this error ACTIVE
Now got this error
ACTIVE(config)# object network Outlook
ACTIVE(config-network)# host 172.16.20.42
ACTIVE(config)#
Navaz
Hi,Which version are you
Which version are you using on the ASA device ?
This should like this:-
ciscoasa(config)# object network outlook
ciscoasa(config-network-object)# host 172.16.20.42
Thanks and Regards,
Vibhor Amrodia
340
