Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
NAT problem - traffic from internet not reaching internal source.
Hi all,
I have just added a 10.8.0.0 /16 network and I am having trouble figuring our why I cannot get trafiic back to devices on this network.  Traffic to/from our existing 172.16.0.0 networks works fine, but not the 10.8 network.  Ping requests are returned, but not internet traffic.  When I look at traffic I see these errors:  "
3          Jul 31 2013          09:07:59          305006          10.8.0.10          56070                              portmap translation creation failed for tcp src inside:74.125.225.128/80 dst inside:10.8.0.10/56070" and
3          Jul 31 2013          09:09:33          305006          10.8.0.10          56071                              portmap translation creation failed for tcp src inside:74.125.225.128/80 dst inside:10.8.0.10/56071"
So, it appears that the traffic is returned, hits the inside interface, but is not being sent back to the proper device.  Can anyone see anything in this config that may be causing this?
Thanks!
ASA Version 8.2(2)
hostname ***-ASA5510
names
name 172.16.250.15 SBS
name 172.16.0.0 inside-nets
interface Ethernet0/0
description Link to ***
nameif outside
security-level 0
ip address ***.***.***.*** 255.255.255.240
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.16.20.1 255.255.255.248
interface Ethernet0/2
shutdown
nameif ***
security-level 0
ip address ***.***.***.*** 255.255.255.252
interface Ethernet0/3
nameif GuestWireless
security-level 0
ip address 172.16.30.1 255.255.255.0
interface Management0/0
nameif management
security-level 100
no ip address
banner exec Unauthorized Access is Prohibited.
banner login No Unauthorized Access.  All Access Attempts Will Be Logged.
banner motd  Authorized Access Only.
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list outside_access_in extended deny ip 150.70.0.0 255.255.0.0 any
access-list outside_access_in remark ICMP type 11 for Windows Traceroute
access-list outside_access_in extended permit icmp any any time-exceeded
access-list outside_access_in remark ICMP type 3 for Cisco and Linux
access-list outside_access_in extended permit icmp any any unreachable
access-list outside_access_in extended permit tcp any host *.*.*.* eq 993
access-list outside_access_in extended permit tcp any host *.*.*.* eq imap4
access-list outside_access_in extended permit tcp any host *.*.*.* eq 4125
access-list outside_access_in extended permit tcp any host *.*.*.* eq https
access-list remote-users_splitTunnelAcl standard permit inside-nets 255.255.0.0
access-list inside_nat0_outbound extended permit ip inside-nets 255.255.0.0 172.16.100.0 255.255.255.0
pager lines 24
logging enable
logging timestamp
logging list Config_Changes level emergencies
logging list Config_Changes message 113019
logging list Config_Changes message 111007-111009
logging list Config_Changes message 113012
logging list vpn-log level debugging class vpnc
logging trap vpn-log
logging asdm notifications
logging facility 23
logging device-id hostname
logging host inside 172.16.250.41
logging debug-trace
logging permit-hostdown
mtu outside 1500
mtu inside 1500
mtu ISP2 1500
mtu GuestWireless 1500
mtu management 1500
ip local pool remote-user-pool 172.16.100.0-172.16.100.254 mask 255.255.255.0
icmp unreachable rate-limit 10 burst-size 5
asdm location inside-nets 255.255.0.0 inside
no asdm history enable
arp timeout 14400
global (outside) 101 interface
global (ISP2) 101 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 101 0.0.0.0 0.0.0.0
nat (GuestWireless) 101 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface smtp SBS smtp netmask 255.255.255.255
static (inside,outside) tcp interface 4125 SBS 4125 netmask 255.255.255.255
static (inside,outside) tcp interface https SBS https netmask 255.255.255.255
static (inside,outside) tcp interface imap4 SBS imap4 netmask 255.255.255.255
static (inside,outside) tcp interface 993 SBS 993 netmask 255.255.255.255
static (inside,outside) tcp interface 6699 Untangle 6699 netmask 255.255.255.255
static (inside,***) *.*.*.* SBS netmask 255.255.255.255 dns
static (inside,outside) [public IP] 172.16.170.10 netmask 255.255.255.255
access-group outside_access_in in interface outside
router ospf 1
network 10.5.0.0 255.255.0.0 area 0
network 10.8.0.0 255.255.0.0 area 0
network inside-nets 255.255.0.0 area 0
log-adj-changes
default-information originate always
route outside 0.0.0.0 0.0.0.0 [Public IP] 1 track 1
route outside 172.16.240.159 255.255.255.255 *.*.*.* 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server SBS-RADIUS protocol radius
reactivation-mode depletion deadtime 1
max-failed-attempts 2
aaa-server SBS-RADIUS (inside) host SBS
key *
radius-common-pw *
aaa authentication ssh console SBS-RADIUS LOCAL
aaa authentication enable console SBS-RADIUS LOCAL
aaa authentication http console SBS-RADIUS LOCAL
aaa authorization exec authentication-server
http server enable
http inside-nets 255.255.0.0 inside
snmp-server host inside 172.16.250.135 community * version 2c
no snmp-server location
no snmp-server contact
snmp-server community *
snmp-server enable traps snmp authentication linkup linkdown coldstart
sla monitor 123
type echo protocol ipIcmpEcho *.*.*.* interface outside
num-packets 3
frequency 10
sla monitor schedule 123 life forever start-time now
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-
192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 65535
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
track 1 rtr 123 reachability
telnet timeout 5
ssh inside-nets 255.255.0.0 inside
ssh timeout 60
ssh version 2
console timeout 0
management-access inside
dhcpd address 172.16.30.100-172.16.30.200 GuestWireless
dhcpd dns *.*.*.* *.*.*.* interface GuestWireless
dhcpd option 3 ip 172.16.30.1 interface GuestWireless
dhcpd enable GuestWireless
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ntp server SBS
webvpn
group-policy remote-users internal
group-policy remote-users attributes
dns-server value 172.16.250.15
vpn-idle-timeout none
vpn-session-timeout none
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value remote-users_splitTunnelAcl
default-domain value ***.local
tunnel-group remote-users type remote-access
tunnel-group remote-users general-attributes
address-pool remote-user-pool
authentication-server-group SBS-RADIUS
default-group-policy remote-users
tunnel-group remote-users ipsec-attributes
pre-shared-key ***
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
  inspect snmp
class class-default
  set connection decrement-ttl
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Super Bronze
Is there something wrong with the routing?
The logs indicate that its trying to create a Dynamic PAT for traffic from "inside" to "inside". The connections should be going to "outside" I would imagine?
The reason you see the "portmap" log message is that the traffic is trying to head out through the "inside" interface and "inside" interface doesnt have any matching "global" command. (Which it shouldnt have I imagine)
So why is the traffic heading to "inside"?
Could you perhaps share the output of
show route
- Jouni
Super Bronze
Re: NAT problem - traffic from internet not reaching internal so
Also,
One thing that can cause the ASA to forward traffic to wrong place are "static" NAT configurations.
But I would imagine that is not the case here.
But I still wonder how/why the traffic is forwarded to "inside" according to the above log messages.
You do have static default route pointing out of the ASA so to my understanding that should be prefered for the public destination IP address shown in the logs no matter what routes the dynamic routing protocol might advertice.
You seem to be using OSPF for the routing. I have never to this day used any dynamic routing protocol on the ASA. It has always been static routing.
- Jouni
Community Member
The routing from inside to inside is confusing me also.  Here is the routing table:
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is [ISP Gateway] to network 0.0.0.0
C    [Public Network] 255.255.255.240 is directly connected, outside
O    172.16.180.0 255.255.255.0 [110/11] via 172.16.20.2, 45:27:17, inside
O    172.16.170.0 255.255.255.0 [110/11] via 172.16.20.2, 45:27:17, inside
O    172.16.250.0 255.255.255.0 [110/11] via 172.16.20.2, 45:27:17, inside
O    172.16.251.0 255.255.255.0 [110/11] via 172.16.20.2, 45:27:17, inside
O    172.16.240.0 255.255.255.0 [110/11] via 172.16.20.2, 45:27:17, inside
O    172.16.230.0 255.255.255.0 [110/11] via 172.16.20.2, 45:27:17, inside
O    172.16.220.0 255.255.255.0 [110/11] via 172.16.20.2, 45:27:17, inside
C    172.16.30.0 255.255.255.0 is directly connected, GuestWireless
C    172.16.20.0 255.255.255.248 is directly connected, inside
S    172.16.240.159 255.255.255.255 [1/0] via [ISP Gateway], outside
O    172.16.99.0 255.255.255.0 [110/11] via 172.16.20.2, 45:27:17, inside
O    10.8.0.0 255.255.0.0 [110/11] via 172.16.20.2, 45:27:17, inside
O    10.5.0.0 255.255.0.0 [110/11] via 172.16.20.2, 45:27:17, inside
S*   0.0.0.0 0.0.0.0 [1/0] via [ISP Gateway], outside
Thanks for the help!
Community Member
Can you launch a packet tracer on the outside interface toward a host in the 10.8.0.0/16 network ?
packet-tracer input outside src-public_ip 1234 10.8.2.2 1234
AM
Community Member
Here's the output of the packet-tracer:
ASA5510# packet-tracer input outside tcp public_ip 1234 10.8.2.2 12$
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.8.0.0        255.255.0.0     inside
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
...so, it seems that an ACL is blocking the return traffic somehow.  I added these two statements to the ACL:
access-list outside_access_in extended permit tcp any 10.8.0.0 255.255.0.0 eq 1234
access-list outside_access_in extended permit ip any 10.8.0.0 255.255.0.0
I reran the packet-tracer and the connection was still blocked by an acl-drop.
ASA5510(config)# packet-tracer input outside tcp public-ip 1234 10.$
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-status: up
output-status: up
Action: drop
I cleared the ACL counter on the outside_access_in ACL and re-ran the packet-tracer:
ASA5510# clear access-list outside_access_in counters
ASA5510# show access-list
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 4096)
            alert-interval 300
access-list outside_access_in; 16 elements; name hash: 0x6892a938
access-list outside_access_in line 1 extended deny ip 150.70.0.0 255.255.0.0 any (hitcnt=0) 0x247e4f19
access-list outside_access_in line 2 remark ICMP type 11 for Windows Traceroute
access-list outside_access_in line 3 extended permit icmp any any time-exceeded (hitcnt=0) 0x03690eb3
access-list outside_access_in line 4 remark ICMP type 3 for Cisco and Linux
access-list outside_access_in line 5 extended permit icmp any any unreachable (hitcnt=1) 0x5c2fa603
access-list outside_access_in line 10 extended permit tcp any host public_ip eq 993 (hitcnt=0) 0x445ffc7a
access-list outside_access_in line 11 extended permit tcp any host public_ip eq imap4 (hitcnt=0) 0xc10d6b17
access-list outside_access_in line 12 extended permit tcp any host public_ip eq 4125 (hitcnt=0) 0xf9904a7e
access-list outside_access_in line 13 extended permit tcp any host public_ip eq https (hitcnt=2) 0x933075d4
access-list outside_access_in line 14 extended permit tcp any host public_ip eq smtp (hitcnt=0) 0xbbbe8a1e
access-list outside_access_in line 15 extended permit tcp any host public_ip eq 6699 (hitcnt=0) 0x67c9552f
access-list outside_access_in line 16 extended permit tcp any host public_ip eq https (hitcnt=0) 0xda2d6a77
access-list outside_access_in line 17 extended permit tcp any 10.8.0.0 255.255.0.0 eq 1234 (hitcnt=0) 0x88dd37e5
access-list outside_access_in line 18 extended permit ip any 10.8.0.0 255.255.0.0 (hitcnt=0) 0xa9169af9
access-list remote-users_splitTunnelAcl; 1 elements; name hash: 0x19f43771
access-list remote-users_splitTunnelAcl line 1 standard permit inside-nets 255.255.0.0 (hitcnt=0) 0x9cd507cd
access-list inside_nat0_outbound; 5 elements; name hash: 0x467c8ce4
access-list inside_nat0_outbound line 1 extended permit ip 172.16.180.0 255.255.255.0 172.16.200.0 255.255.255.0 (hitcnt=0) 0xbc5b1ea5
access-list inside_nat0_outbound line 2 extended permit ip 172.16.180.0 255.255.255.0 172.16.210.0 255.255.255.0 (hitcnt=0) 0xbff6a7ce
access-list inside_nat0_outbound line 3 extended permit ip 172.16.180.0 255.255.255.0 172.16.190.0 255.255.255.0 (hitcnt=0) 0x19b50b54
access-list inside_nat0_outbound line 4 extended permit ip tascet-inside-nets 255.255.0.0 172.16.100.0 255.255.255.0 (hitcnt=0) 0xba71f6d5
access-list inside_nat0_outbound line 5 extended permit ip 172.16.180.0 255.255.255.0 172.16.240.0 255.255.255.0 (hitcnt=0) 0x00a7b064
ASA5510# packet-tracer input outside tcp 66.170.26.242 1234 8.0.2.2 123$
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-status: up
output-interface: outside
output-status: up
Action: drop
            alert-interval 300
access-list inside_nat0_outbound line 4 extended permit ip inside-nets 255.255.0.0 172.16.100.0 255.255.255.0 (hitcnt=0) 0xba71f6d5
I am not seeing the ACL that is blocking traffic here - I'm baffled.  any ideas?
Super Bronze
There is not much point in trying to simulate a connection coming from the "outside" to your "inside" network with the private IP address as the destination as no such packet will ever reach your firewall.
Can you try doing a "packet-tracer" to simulate a new connection being formed from the new LAN Network
packet-tracer input inside tcp 10.8.2.2 12345 8.8.8.8 80
And see if it gives us any information.
The original log messages still seem really strange to me.
- Jouni
Community Member
That seemed to work just fine:
ASA5510# packet-tracer input inside tcp 10.8.2.2 12345 8.8.8.8 80
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 4
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
class-map class-default
match any
class class-default
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: NAT
Subtype:
Result: ALLOW
Config:
  match ip inside any outside any
    dynamic translation to pool 101 (public_ip [Interface PAT])
    translate_hits = 964843, untranslate_hits = 39941
Dynamic translate 10.8.2.2/12345 to public_ip/51088 using netmask 255.255.255.255
Phase: 7
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 1300556, packet dispatched to next module
Result:
input-interface: inside
input-status: up
output-status: up
Action: allow
Super Bronze
I would suggest going through the whole path of the network from the host in the new network all the way to its default Internet gateway where its default route leads to and again back to the host from that Internet gateway viewing routing table on each step. I would imagine that are atleast some routers involved as you decided to use a routing protocol instead of static routing.
I am just wondering if this would have anything to do with you possibly having another Internet gateway in addition to the ASA and the traffic taking a "wrong turn" somewhere along the way in your network?
At first glance the log message would seem to point to a situation where a connection from the host might have gone to the Internet through some other Internet gateway (other than the ASA) and the return traffic has come back to the ASA from that Internet gateway before reaching the actual host.
- Jouni
Community Member
I've got layer 3 switches doing routing in my network.  The traffic from the 10.8.0.0 network is coming from the switch below.  The default route is to the inside interface of the firewall (172.16.20.1).  The ASA's routing table (shown above) then has a default gateway set to the ISP's gateway address.  Should the default gateway on the switch be set to the ISP's Gateway address?
Edit:  There are no other paths out of the network.
"switch1"#sh ip ro
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 172.16.20.1 to network 0.0.0.0
     172.16.0.0/16 is variably subnetted, 11 subnets, 3 masks
C       172.16.180.0/24 is directly connected, Vlan180
C       172.16.170.0/24 is directly connected, Vlan170
C       172.16.250.0/24 is directly connected, Vlan250
C       172.16.251.0/24 is directly connected, Vlan251
C       172.16.240.0/24 is directly connected, Vlan240
C       172.16.230.0/24 is directly connected, Vlan230
C       172.16.220.0/24 is directly connected, Vlan220
O       172.16.30.0/24 [110/11] via 172.16.20.1, 6d23h, GigabitEthernet1/0/48
C       172.16.20.0/29 is directly connected, GigabitEthernet1/0/48
S       172.16.240.159/32 [1/0] via 172.16.20.1
C       172.16.99.0/24 is directly connected, Vlan99
     10.0.0.0/16 is subnetted, 2 subnets
C       10.8.0.0 is directly connected, Vlan108
C       10.5.0.0 is directly connected, Vlan105
S*   0.0.0.0/0 [1/0] via 172.16.20.1
Super Bronze
Routing seems correct. Default gateway should be pointing to the ASA "inside" interface IP address like it is at the moment.
I don't know why we would see the ASA at any point trying to create a translation from "inside" to "inside".
The most common reason I have seen for an ASA to forward traffic through wrong interface has been some NAT configuration but I cant see anything in your configuration that would point to such a problem.
I can't remember ever running into such a situation myself so I dont even have that advantage when trying to see what this problem is about.
You could always consider rebooting the ASA and see if it has any effect on the current problem (remember to save configuration if you device to do so)
Other options would be to further try to get logs from connection attempts from a single host.
There is also the option of trying to capture some traffic on the ASA if it would tell anything about the problem.
I just dont see a reason why this network wouldnt work if all other networks behind "inside" work at the moment.
- Jouni
Community Member
Jouni,
Exactly right, all other inside networks (except the 10.5.0.0, which is also new) are routing and NATing just fine.  Also, I'm curious as to why ICMP traffic is routed properly to and from the 10.8.0.0 network, but not http or other tcp traffic.  I will bounce the ASA, but I'll have to wait until the evening.  Thanks for your help thus far.
-Shane
Super Bronze
In some cases where routing is the problem ICMP might act a bit differently than TCP connections for example.
ICMP might work and TCP not because of asymmetric routing. (especially when ASA is in the picture)
Looking at your L3 Switch routing table I can only see ONE network adverticed with OSPF and its from the ASA. And since the ASA is the default gateway it wouldnt even need to advertice that network as the traffic would always come to the ASA with default route.
So I am not sure where the OSPF is needed in this case since it seems to only run between the L3 switch and ASA. I would personally handle it with Static routing at both ASA and L3 switch since the OSPF doesnt really bring that much into the picture.
You would only need static default route from L3 Switch towards ASA and ASA would need route for the LAN network towards its "inside" interface.
It just somehow seems to me like something to do with routing but doesnt make sense especially when the ASA should be the only route out of your network.
- Jouni
Community Member
Shane,
There is one obvious mistake in your OSPF configuration that may lead to this confusion. You are advertising networks that are not directly connected to your ASA. As shown, these networks are directly connected to the switch through Vlans 108 and 105. This means that the switch need to advertise them to the ASA not the vice-versa. After all, ASA want to reach these networks in order to serve them so they must get advertised by the switch. Remember the "network" command is used to define which networks the device knows to advertise them to other devices.
Can you just create static routes to these destinations with the switch as the default gateway and see what will happen?
AM
Community Member
Also, i noticed that there is an object group defined called "inside-nets" in OSPF config. Is this the 172.16.0.0 major network behind the switch? ... When you said that there is no problem with traffic coming from/to 172.16.0.0, did you mean the 172.16 networks behind the switch OR the 172.16.30.0 and 172.16.20.0 that are directly connected to ASA? Did you try to initiate traffic from any of 172.16 networks that are behind the switch?
AM
738
