NAT using different IP range than on outside interface
I have a need to use another class C subnet for outbound NAT purposes, but this new range isn't bound to the outside interface. Is this possible?
Outside interface IP: 1.1.1.1/24
Inside interfac ip: 10.1.1.x/24
New block: 192.168.1.0/24
New inside hosts needing nat on new range: 10.14.1.x/24
So basically I want to use a range of ip's not bound to and interface to use as the PAT'd address when the packet leaves the ASA. What would this config look like?
Thx
1 REPLY
Gold
Re: NAT using different IP range than on outside interface
Yes it is possible (atleast with 8.2) but only for inbound connections, otherwise you would have a routing problem since it does not support policy based routing.
Just configure it as you would do a normal static but with the address from the other net and it will work just fine.
do not forget to allow the traffic in an ACL
Good luck
248
