Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
NAtting on ASA with Citrix connection.
Hi everyone,
I am accessing my corp network via citrix client.
Here are logs from internet ASA when i use citrix
TCP outside 70.75..x.x:52705 Internal 10.31.35.10:443, idle 0:00:00, bytes 3614224, flags UIOB
This tells us that connection is coming from outside interface of ASA and going to Internal IP 10.31.35.10.
Where 70.75 is MY PC IP.
Here is Natting on ASA
nat (Internal) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
This NAT tells us that if source is any and coming from Internal  then translate it to the Public IP of outside interface which will be PAT right?
Here is static nat config for Citrix
static (Internal,outside) 210.x.x.x  10.31.35.10 netmask 255.255.255.255
where 10.31.35.10 is internal IP of citrix server and 210.x.x.x is global IP.
Need to understand when i open the url with global ip which is 210.x.x.x it comes to the ASA and first hits the outside interface then it hits
the static nat rule which says if destination is 210.x.x then translate this into internal IP of server which is 10.31.35.10.
Mahesh
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: NAtting on ASA with Citrix connection.
Mahesh
The nat/global statements translate all source IPs to the outside interface IP address when going from inside to outside. In terms of your Citrix access this rule does not do anything because you have a static NAT statement which takes precedence.
The static NAT statement does exactly what you say.
So your PC src IP is never translated because coming in from the internet it is the source IP and you do not have a rule to translate those and going back to your PC is it the destination IP and again you do not have a rule to translate that.
Note when i say you don't have rules i mean from what you have posted as there may well be other rules on the firewall.
Jon
Mahesh
Jon
Thanks John for  replying to my question.
Mahesh
99
