Need Configuration Document of Cisco ASA 5540 ,10
Can you please share the all video links and configuration guide (CLI and GUI) of ASA 5510,40
Manoj
  • Firewalling
Hall of Fame Super Silver
There are hundreds of Cisco
There are hundreds of Cisco documents on the product support page.
There are also at least a dozen good books published as well as many many user-contributed videos on YouTube.
Also see the Documents and Videos tabs at the top of this Firewalling forum space as well as the VPN space.
VIP Green
I answered this in your other
I answered this in your other post but I will post it here also.
I am not sure which video links you are referring to. If you are referring to configuration videos, then youtube has hundreds of them.  Just search for what you want to configure.
As for configuration guides, the following webpage provides links to configuration guides for the different versions of ASA.  Just select the software verion guide you are configuring:
http://www.cisco.com/c/en/us/support/security/asa-5500-series-next-generation-firewalls/products-installation-and-configuration-guides-list.html
Please remember to select a correct answer and rate
-- Please remember to rate and select a correct answer
38
