Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Need fluid traffic between two same security level interfaces
Dear Sirs I am configuring an ASA5510 before implementing it on my network. I have 1 ISP for internet connected to Outside Interface, a DMZ Interfaces and 2 inside interfaces. One of these inside interfaces is Outside1 will be connected to a router that will have Fiber and Antenas for communicating with our small offices. I need fluid traffic between Inside an Outside1. I tried using some advices but still not working. Here's my configuration. Can you help me?
: Saved
ASA Version 8.2(1)
hostname ASAFCHFW
domain-name farmaciachavez.com.bo
enable password 6Jfo5anznhoG00fM encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
nameif Outside
security-level 0
ip address X.X.X.X y.y.y.y
interface Ethernet0/1
nameif Outside1
security-level 100
ip address 192.168.2.2 255.255.255.0
interface Ethernet0/2
nameif DMZ
security-level 10
ip address 172.16.31.1 255.255.255.0
interface Ethernet0/3
nameif Inside
security-level 100
ip address 192.168.100.1 255.255.255.0
interface Management0/0
nameif management
security-level 100
management-only
boot system disk0:/asa821-k8.bin
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list dmz_in extended permit ip any any
access-list dmz_in extended permit icmp any any
access-list Inside extended permit ip any any
access-list Inside extended permit icmp any any
access-list 100 extended permit tcp any host x.x.x..163 eq smtp
access-list 100 extended permit udp any host x.x.x.163 eq domain
access-list 100 extended permit tcp any host x.x.x.163 eq https
access-list 100 extended permit tcp any host x.x.x.163 eq www
pager lines 24
logging enable
logging asdm informational
mtu Outside 1500
mtu Outside1 1500
mtu DMZ 1500
mtu Inside 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit 192.168.100.0 255.255.255.0 Outside1
icmp permit 192.168.2.0 255.255.255.0 Inside
asdm image disk0:/asdm-647.bin
asdm history enable
arp timeout 14400
global (Outside) 101 interface
nat (DMZ) 101 0.0.0.0 0.0.0.0
nat (Inside) 101 0.0.0.0 0.0.0.0
static (Inside,DMZ) 192.168.100.0 192.168.100.0 netmask 255.255.255.0
static (DMZ,Outside) x.x.x.163 172.16.31.0 netmask 255.255.255.255
static (DMZ,Inside) 172.16.31.0 172.16.31.0 netmask 255.255.255.0
access-group 100 in interface Outside
access-group dmz_in in interface DMZ
route Outside 0.0.0.0 0.0.0.0 x.x.x.161 1
route Outside1 172.1.1.0 255.255.255.0 192.168.2.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
http 192.168.100.0 255.255.255.0 Inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:b5e4725e47eea02221510b282e9e5843
: end
Thanks in advanced
Eduardo Guerra
1 ACCEPTED SOLUTION
Can you post the results of this command?
packet-tracer input inside tcp 192.168.100.5 9823 192.168.2.10 80 detail
and
packet-tracer input Outside1 tcp 192.168.2.10 9823 192.168.100.5 80 detail
So is there no communications from inside to outside1?
Yes, there is no communication. I tried pinging from a computer connected to Inside to computer connected to Outside1 and viceversa, also i tried to access shared resources from each computer with negative results
EG
Try to use the following command"
- Prateek Verma
and
Here are the results:
packet-tracer input inside tcp 192.168.100.5 9823 192.168.2.10 80 detail     (Last 2 Phases)
Phase: 5
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
  match ip Inside 192.168.100.0 255.255.255.0 DMZ any
    static translation to 192.168.100.0
    translate_hits = 0, untranslate_hits = 471
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xab9355d0, priority=5, domain=host, deny=false
        hits=1611, user_data=0xab934f90, cs_id=0x0, reverse, flags=0x0, protocol
=0
        src ip=192.168.100.0, mask=255.255.255.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 6
Type: NAT
Subtype:
Result: DROP
Config:
  match ip Inside any Outside1 any
    dynamic translation to pool 101 (No matching global)
    translate_hits = 94, untranslate_hits = 0
in  id=0xab9309e8, priority=1, domain=nat, deny=false
        hits=93, user_data=0xabeffa80, cs_id=0x0, flags=0x0, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
Result:
input-interface: Inside
input-status: up
input-line-status: up
output-interface: Outside1
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
packet-tracer input Outside1 tcp 192.168.2.10 9823 192.168.100.5 80 detail      (Last 2 Phases)
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xab7f6198, priority=0, domain=permit-ip-option, deny=true
        hits=776, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 6
Type: NAT
Subtype:
Result: DROP
Config:
nat (Outside1) 101 0.0.0.0 0.0.0.0
  match ip Outside1 any Inside any
    translate_hits = 1, untranslate_hits = 0
in  id=0xac0c13f8, priority=1, domain=nat, deny=false
        hits=0, user_data=0xac0c1338, cs_id=0x0, flags=0x0, protocol=0
Result:
input-interface: Outside1
input-status: up
output-interface: Inside
output-status: up
Action: drop
Also i added this command:
EG
Try to put in following commands:
static (Inside,outside1) 192.168.100.0 192.168.100.0 netmask 255.255.255.0
static (outside1,Inside) 192.168.2.0 192.168.2.0 netmask 255.255.255.0
- Prateek Verma
Dear Prateek, configurationo is like this and i can connect between interfaces but i cant access to network 172.1.1.0 that is connected to another router that is connected to interface Outside1. Any suggestion for this?
ASA Version 8.2(1)
hostname ASAFCHFW
names
nameif Outside
security-level 0
ip address 200.87.200.162 255.255.255.248
nameif Outside1
security-level 100
ip address 192.168.2.1 255.255.255.0
nameif DMZ
security-level 10
nameif Inside
security-level 100
ip address 192.168.0.1 255.255.255.0
nameif management
security-level 100
management-only
ftp mode passive
access-list 100 extended permit tcp any host 200.87.226.163 eq smtp
access-list 100 extended permit udp any host 200.87.226.163 eq domain
access-list 100 extended permit tcp any host 200.87.226.163 eq https
access-list 100 extended permit tcp any host 200.87.226.163 eq www
pager lines 24
logging enable
mtu Outside 1500
mtu Outside1 1500
mtu DMZ 1500
mtu Inside 1500
mtu management 1500
icmp permit 192.168.0.0 255.255.255.0 Outside1
icmp permit 192.168.2.0 255.255.255.0 Outside1
icmp permit 192.168.0.0 255.255.255.0 Inside
asdm history enable
arp timeout 14400
static (DMZ,Outside) 200.87.200.163 172.16.31.0 netmask 255.255.255.255
static (Outside1,Inside) 192.168.2.0 192.168.2.0 netmask 255.255.255.0
static (Inside,DMZ) 192.168.0.0 192.168.0.0 netmask 255.255.255.0
static (Inside,Outside1) 192.168.0.0 192.168.0.0 netmask 255.255.255.0
route Outside 0.0.0.0 0.0.0.0 200.87.200.161 1
route Outside1 172.1.1.0 255.255.255.0 192.168.2.2 1
http server enable
http 192.168.0.0 255.255.255.0 Inside
telnet 192.168.0.0 255.255.255.0 Inside
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
Cryptochecksum:6dfac383495fa18bde8783c7d47c3d81
: end
Thanks in advanced
EG
What happens if you increase the routing distance for the default route, e.g.
  route Outside 0.0.0.0 0.0.0.0 200.87.200.161 20
-- Jim Leinweber, WI State Lab of Hygiene
Default route is for internet use. Another static route is for connecting headquater with another offices
EG
I've modified route like James told but no changes. I run a this packet tracer and result is this
Packet Tracer:
packet-tracer input inside tcp 192.168.0.5 9823 172.1.1.10 80 detail
Result:
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   172.1.1.0       255.255.255.0   Outside1
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0xab8755c8, priority=2, domain=permit, deny=false
        hits=175, user_data=0x0, cs_id=0x0, flags=0x3000, protocol=0
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xab877570, priority=0, domain=permit-ip-option, deny=true
        hits=299, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
  match ip Inside 192.168.0.0 255.255.255.0 Outside1 any
    static translation to 192.168.0.0
    translate_hits = 179, untranslate_hits = 18292
Static translate 192.168.0.0/0 to 192.168.0.0/0 using netmask 255.255.255.0
in  id=0xab94c948, priority=5, domain=nat, deny=false
        hits=175, user_data=0xab94c0a0, cs_id=0x0, flags=0x0, protocol=0
        src ip=192.168.0.0, mask=255.255.255.0, port=0
Phase: 6
Type: NAT
Result: ALLOW
Config:
  match ip Inside 192.168.0.0 255.255.255.0 DMZ any
    translate_hits = 0, untranslate_hits = 11
in  id=0xab811c80, priority=5, domain=host, deny=false
        hits=18742, user_data=0xab8d1270, cs_id=0x0, reverse, flags=0x0, protoco
l=0
Phase: 7
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
    translate_hits = 309, untranslate_hits = 0
out id=0xab93f558, priority=1, domain=nat-reverse, deny=false
        hits=74, user_data=0xab93f2e8, cs_id=0x0, flags=0x0, protocol=0
Result:
input-status: up
output-status: up
Action: drop
Any ideas for solving this route issue?
EG
There is no NAT so it's failing.
Phase: 7
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
Have you tried Prateek's commands?
Prateek's commands are one way to fix it.
You could also try-
global (Inside) 102 interface
nat (Outside1) 102 0 0
Dear Collin, do these lines:
will not restrict traffic to the internet by interface Outside?
EG
Those lines will nat traffic from Outside1 to the Inside using the IP assigned to the Inside interface.
Collin, Here's my network diagram. I need to use static routes from Lan to 172.1.x.x to communicate other offices with headquater LAN (I need NAT no PAT as you suggested answer before). Also i need to communicate branch offices with email server. Actually the service router i am using to connect branch offices is Cisco RV016 but in the near future it will be ISR G2 Cisco 892
If you need some more explanation to solve routing issue, please tell. also here's the up to date configuration
ASA Version 8.2(1)
hostname ASAFCHFW
names
nameif Outside
security-level 0
ip address x.x.x.162 255.255.255.248
nameif Outside1
security-level 100
nameif DMZ
security-level 10
nameif Inside
security-level 100
nameif management
security-level 100
management-only
ftp mode passive
access-list 100 extended permit tcp any host x.x.x.163 eq smtp
pager lines 24
logging enable
mtu Outside 1500
mtu Outside1 1500
mtu DMZ 1500
mtu Inside 1500
mtu management 1500
asdm history enable
arp timeout 14400
route Outside 0.0.0.0 0.0.0.0 x.x.x.161 20
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
Cryptochecksum:3235bd0aa15e755b360cd2fb30b227ef
: end
EG
So the satelitte offices connect to Inside to access ERP, voice, video, etc and you do not want them to NAT? They also need to get out to the internet through your firewall for email correct?
Yes, you are right
Also email must be able for LAN users, and branch offices users. I have communication between Inside and DMZ (Email server is on DMZ) so LAN users can connect to email.
EG
Try-
static (outside1,DMZ) 172.16.31.0 172.16.31.0 netmask 255.255.255.0
Dear Collin, those lines are already inserted in the conf. I cannot reach anyway network 172.1.x.x even if i have static route to that network (i have point that network 172.1.x.x is connected to a router that is connected to interface Outside1). Do i have to insert an ACL or what should i do to reach that network
EG
From the router in the diagram can you access anything in the Inside or DMZ?
Collin, I tried to connect to a computer within the network connected to Inside but cannot communicate didn't try to DMZ but i will try
EG
Any suggestions?
Are you positive that all the routing is in place?
On the ASA debug ICMP
logging enable
logging buffered 7
debug icmp trace
Then from the router or beyond, try and ping a resource in the ASA LAN side. The ping may fail, but do a show logg on the ASA and you should see some icmp debug traffic. Please post that debug.
Collin, answering to this Q:
"From the router in the diagram can you access anything in the Inside or DMZ?", posted by you. I can access to Inside from the router.
I will try
ICMP debug as you adviced
EG
Dear Collin, this is the logg:
%ASA-4-411001: Line protocol on Interface Ethernet0/3, changed state to up
%ASA-4-411001: Line protocol on Interface Inside, changed state to up
%ASA-7-711002: Task ran for 18 msec, Process = NIC status poll, PC = 88e0c93, Tr
aceback =
aceback =   0x088E0C93  0x08062413
%ASA-6-302010: 0 in use, 25 most used
%ASA-5-111007: Begin configuration: console reading from terminal
%ASA-5-111008: User 'enable_15' executed the 'configure terminal' command.
%ASA-5-111008: User 'enable_15' executed the 'logging enable' command.
%ASA-5-111008: User 'enable_15' executed the 'logging buffered 7' command.
%ASA-5-111008: User 'enable_15' executed the 'debug icmp trace' command.
%ASA-5-111005: console end configuration: OK
%ASA-5-111001: Begin configuration: console writing to memory
%ASA-5-111004: console end configuration: OK
%ASA-5-111008: User 'enable_15' executed the 'write' command.
%ASA-7-111009: User 'enable_15' executed cmd: show running-config
ASAFCHFW# ICMP echo request from 192.168.0.20 to 192.168.0.1 ID=768 seq=1792 len
=32
ICMP echo reply from 192.168.0.1 to 192.168.0.20 ID=768 seq=1792 len=32
ICMP echo request from 192.168.0.20 to 192.168.0.1 ID=768 seq=2048 len=32
ICMP echo reply from 192.168.0.1 to 192.168.0.20 ID=768 seq=2048 len=32
ICMP echo request from 192.168.0.20 to 192.168.0.1 ID=768 seq=2304 len=32
ICMP echo reply from 192.168.0.1 to 192.168.0.20 ID=768 seq=2304 len=32
ICMP echo request from 192.168.0.20 to 192.168.0.1 ID=768 seq=2560 len=32
ICMP echo reply from 192.168.0.1 to 192.168.0.20 ID=768 seq=2560 len=32
ICMP echo request from Inside:192.168.0.20 to Outside1:192.168.2.22 ID=768 seq=2
816 len=32
ICMP echo reply from Outside1:192.168.2.22 to Inside:192.168.0.20 ID=768 seq=281
6 len=32
ICMP echo request from Inside:192.168.0.20 to Outside1:192.168.2.22 ID=768 seq=3
072 len=32
ICMP echo reply from Outside1:192.168.2.22 to Inside:192.168.0.20 ID=768 seq=307
2 len=32
328 len=32
ICMP echo reply from Outside1:192.168.2.22 to Inside:192.168.0.20 ID=768 seq=332
8 len=32
584 len=32
ICMP echo reply from Outside1:192.168.2.22 to Inside:192.168.0.20 ID=768 seq=358
4 len=32
840 len=32
ICMP echo reply from Outside1:192.168.2.22 to Inside:192.168.0.20 ID=768 seq=384
0 len=32
ICMP echo request from Inside:192.168.0.20 to Outside1:192.168.2.22 ID=768 seq=4
096 len=32
ICMP echo reply from Outside1:192.168.2.22 to Inside:192.168.0.20 ID=768 seq=409
6 len=32
352 len=32
ICMP echo reply from Outside1:192.168.2.22 to Inside:192.168.0.20 ID=768 seq=435
2 len=32
608 len=32
ICMP echo reply from Outside1:192.168.2.22 to Inside:192.168.0.20 ID=768 seq=460
8 len=32
864 len=32
ICMP echo reply from Outside1:192.168.2.22 to Inside:192.168.0.20 ID=768 seq=486
4 len=32
ICMP echo request from Inside:192.168.0.20 to Outside1:192.168.2.22 ID=768 seq=5
120 len=32
ICMP echo reply from Outside1:192.168.2.22 to Inside:192.168.0.20 ID=768 seq=512
0 len=32
376 len=32
ICMP echo reply from Outside1:192.168.2.22 to Inside:192.168.0.20 ID=768 seq=537
6 len=32
632 len=32
ICMP echo reply from Outside1:192.168.2.22 to Inside:192.168.0.20 ID=768 seq=563
2 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=13568 len=32
Denied ICMP type = 8, code = 0 from 172.1.1.20on interface 4
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=14080 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=14848 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=15360 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=15872 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=16384 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=17152 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=17920 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=18688 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=19456 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=20224 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=20992 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=21760 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=22528 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=23296 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=24064 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=24832 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=25600 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=26368 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=27136 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=27904 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=28672 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=29440 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=30208 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=30976 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=31744 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=32512 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=33280 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=34048 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=34816 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=35584 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=36352 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=37120 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=37888 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=38656 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=39424 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=40192 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=40960 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=41728 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=42496 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=43264 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=44032 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=44800 len=32
Any suggestions?
So sorry, after show logg, this result
ASAFCHFW# ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=4359 len=3
sh logg
Syslog logging: enabled
    Facility: 20
    Timestamp logging: disabled
    Standby logging: disabled
    Debug-trace logging: disabled
    Console logging: disabled
    Monitor logging: disabled
    Buffer logging: level debugging, 2470 messages logged
    Trap logging: disabled
    History logging: disabled
    Device ID: disabled
    Mail logging: disabled
    ASDM logging: level informational, 456484 messages logged
192.168.0.1/0 laddr 192.168.0.1/0
%ASA-3-313001: Denied ICMP type=8, code=0 from 172.1.1.20 on interface Inside
%ASA-6-302021: Teardown ICMP connection for faddr 172.1.1.20/768 gaddr 192.168.0
%ASA-7-609002: Teardown local-host Inside:172.1.1.20 duration 0:00:02
%ASA-7-609002: Teardown local-host identity:192.168.0.1 duration 0:00:02
%ASA-7-609001: Built local-host Inside:172.1.1.20
%ASA-7-609001: Built local-host Outside1:192.168.2.20
%ASA-3-305006: portmap translation creation failed for icmp src Inside:172.1.1.2
0 dst Outside1:192.168.2.20 (type 8, code 0)
%ASA-7-609002: Teardown local-host Inside:172.1.1.20 duration 0:00:00
%ASA-7-609002: Teardown local-host Outside1:192.168.2.20 duration 0:00:00
%ASA-7-609001: Built local-host identity:192.168.0.1
<--- More --->ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=5127 l
en=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=5639 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=6663 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=7175 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=7943 len=32
%tion 0:00:02
%ASA-6-302020: Built inbound ICMP connection for faddr 172.1.1.20/768 gaddr 192.
%ASA-7-609001: Built local-host Outside1:192.168.2.22
0 dst Outside1:192.168.2.22 (type 8, code 0)
%ASA-7-609002: Teardown local-host Outside1:192.168.2.22 duration 0:00:00
ASAFCHFW# ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=8455 len=3
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=9735 len=32
ICMP echo request from 172.1.1.20 to 192.168.0.1 ID=768 seq=9991 len=32
ASAFCHFW#
1039
