Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Need help for NAT, ACL for VoIP
Dear experts
I configure my PBX server to work with one VoIP provider. When I put the server in blank network, mean that without VLANs.
The IP PBX server can register to the VoIP provider system normally and I can make call out and receive calls normally.
However,  when I put the PBX behind the Cisco router with some configuration. The  PBX cannot register with the VoIP provider system.
Eventhough I can receive calls from outside but can not make a call from inside to outside, because of the PBX cannot register.
Could you please help me to point out what is wrong with my Cisco router configuration.
Thanks a lot
Building configuration...
Current configuration : 1982 bytes
! Last configuration change at 17:18:27 UTC Mon Feb 24 2014
version 15.1
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$ZJEF$8np0QvQTD1nTaOosa9yGW1
no aaa new-model
memory-size iomem 20
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO2911/K9 sn FTX1603AH9C
interface Embedded-Service-Engine0/0
no ip address
interface GigabitEthernet0/0
description internal-LAN
ip address x.x.x.4 255.255.0.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 11
ip address 172.x.x.1 255.255.240.0
interface GigabitEthernet0/2
description internet
ip address 50.x.x.93 255.255.x.x
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface GigabitEthernet0/2 overload
ip nat inside source static udp x.x.x.8 5060 50.x.x.93 5060 extendable
ip route profile
ip route 0.0.0.0 0.0.0.0 50.x.x.94
ip route 172.16.240.0 255.255.x.0 x.x.x.5
ip route 172.16.242.0 255.255.x.0 x.x.x.5
access-list 100 permit ip x.x.0.0 0.0.255.255 any
access-list 100 permit ip 172.16.240.0 0.0.0.255 any
access-list 100 permit ip 172.16.242.0 0.0.0.255 any
access-list 100 permit udp any any range 5004 5090
access-list 100 permit udp any any range 10000 20000
control-plane
line con 0
1 REPLY
Hello.
Do you have the same static NAT mapping for TCP 5060?
132
