Need Help on one Firewall Question
Hi All,
I am using cisco asa in my environment and which is connected to l2. One server and one router is also connected to L2. Now i want to access port 80 on my server from outside.
How its possible if the server gateway is routers ip and i don't want to add static route in router or server towards the firewall. Nat and access List is done on firewall. what else i can do on firewall to access port 80 of my server from outside. Dont want to change anything on router/server.
Below is the IP detail
1. Firewall inside 192.168.1.1 & Outside 1.1.1.1
2. Router IP - 192.168.1.2
3. Server IP - 192.168.1.3 & GW - 192.168.1.2
Super Bronze
According to your explanation the packets would arrive on the ASA and reach the server but the server would forward them through the router which would then probably forward them through another Internet connection or what is the default gateway of the router?
If its something else than the ASA then the connections will fail.
- Jouni
Hi Jouni,
Thanks for Reply
Yes the default gateway is something else than the ASA and the connection getting failed. But is there any configuration which we can done on firewall to make it work. I hear from someone that we can done some mapping on firewall with that server and it should work even if the default gateway of server is different. and if the GW of router is not asa.
Super Bronze
What is the software level of your firewall?
- Jouni
Its Pix Firewall 7.2
Super Bronze
Re: Need Help on one Firewall Question
Well the only ways I could think that the connections could be gotten working would be
  • Policy Based Routing on the Router that would forward the web servers traffic through the firewall instead of the routers default gateway (even just the return traffic for web connections)
  • Configuring NAT on the ASA firewall so that all traffic from the Internet would be NATed to an internal IP address from the network 192.168.1.0/24. This would mean that the server would be sending the traffic to ASA instead of using its default gateway. And this is ofcourse because the server would be seeing all connections coming from its connected network and wouldnt have to use the default gateway.
You havent mentioned what type of NAT you are doing on the ASA for the server Static PAT or Static NAT. Static PAT would be forwarding a single (or several ports) only while Static NAT would be dedicating a single public IP address for the server.
I would imagine that you would have to configure 2 separate NAT statements
Dynamic Policy PAT for the External hosts
  • This should NAT all traffic coming from the Internet to the IP address of your ASAs "inside" interface WHEN the destination is the public IP address of your Web server.
access-list POLICY-NAT-WEBSERVER remark NAT inbound web traffic to an internal IP address
access-list POLICY-NAT-WEBSERVER permit tcp any host 1.1.1.1 eq 80
nat (outside) 100 access-list POLICY-NAT-WEBSERVER
global (inside) 100 interface
Static NAT or Static PAT for Web server
  • Either of these NAT configurations should forward the connections to your Web servers public IP address on port TCP/80 to the Web server.
  • Together with the above NAT configuration the return traffic from the Web server should flow back through the ASA.
static (inside,outside) 1.1.1.1 192.168.1.3 netmask 255.255.255.255
or
static (inside,outside) tcp 1.1.1.1 80 192.168.1.3 80 netmask 255.255.255.255
If you are using the public IP address on the ASA "outside" interface then replace the 1.1.1.1 with "interface". The IP address 1.1.1.1 stands for a public IP address that you might use.
Hope this helps
Please do remember to mark a reply as the correct answer if it answered your question.
Feel free to ask more if needed
- Jouni
Have done the following configuration only.
access-list server permit tcp any host 192.168.1.3 eq 80
Now according to you need to add Dynamic policy as well for external hosts.
Will try and reply you.
Super Bronze
Yes, the Static PAT (Port Forward) that you have configured will forward the traffic to your Web server but the return traffic will still be forwarded to the router by the web server and the connections will fail.
However, if we configure the Dynamic Policy PAT which NATs any users on the Internet to your firewalls "inside" interface local IP address then the Web server will send the return traffic there since host communicating in the same subnet will always send the traffic directly to eachother.
- Jouni
Hi Jouni,
Have tried but no luck. Below is my configuration.
interface GigabitEthernet0
nameif outside
security-level 0
ip address 1.1.1.1 255.255.255.0
interface GigabitEthernet1
nameif inside
security-level 100
object network WEBSERVER
host 192.168.1.3
access-list WEBSERVER extended permit tcp any host 192.168.1.3 eq www
access-list WEBSERVER extended permit tcp any host 1.1.1.1 eq www
nat (inside,outside) static interface service tcp www www
access-group WEBSERVER in interface outside
nat (outside) 100 access-list WEBSERVER
Have tried this on ASA version 8.4
Super Bronze
You said you had PIX 7.2?
The NAT configuration format I provided only works up to software level 8.2
At 8.3 and after the configuration format is totally different.
Which one are you using?
- Jouni
Today i have tried on ASA with software version 8.4.
Super Bronze
In the new format you might be able to do both of the NAT configurations with a single "nat" command
host 192.168.1.3
object service WWW
service tcp source eq www
nat (inside,outside) source static WEBSERVER interface destination static interface any service WWW WWW
This should both do Static PAT for your Webserver and translate any source address on the Internet to the "inside" interface IP address WHEN they access your Web server through TCP/80
Hope this helps
- Jouni
Hi Jouni,
Thanks Alot for help. Its working fine now.
Can you please share me the commands for Version 7.2 also.
Super Bronze
I provided that configuration in the earlier replies. The ones done with "static" , "nat" and "global" configurations.
I have not tested the setup myself but it would seem like the only way to do it that I can think of at the moment.
Please do remember to mark a reply as the correct answer if it has answered your question.
- Jouni
Hi Jouni,
Have tried with earlier configuration but no luck..
Super Bronze
If you have those old NAT format configurations on your PIX firewall then I would like to see the output of a "packet-tracer" command simulating a connection coming for your webserver
It would be something like this
packet-tracer input outside tcp 123.123.123.123 12345 80
This should tell us what NAT rules are matched on the firewall for such a connection. Just enter your public IP address used for the Web servers NAT command.
- Jouni
Please find the bleow report.
packet-tracer input outside tcp 1.1.1.2 www 1.1.1.1  www
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
static (inside,outside) tcp interface www 192.168.1.3 www netmask 255.255.255.255
  match tcp inside host 192.168.1.3 eq 80 outside any
    static translation to 1.1.1.1/80
    translate_hits = 0, untranslate_hits = 10
NAT divert to egress interface inside
Untranslate 1.1.1.1/80 to 192.168.1.3/80 using netmask 255.255.255.255
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 6
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 10, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
Super Bronze
Only situation where I managed to get this working was when I configured
nat (outside) 100 0.0.0.0 0.0.0.0 outside
I tried to configure Dynamic Policy PAT on the "outside" -> "inside" but it didnt seem to work.
- Jouni
283
