Need Help on Port Blocking in ASA
Dear All,
I have configured firewall and allow only port 443 and deny all tcp ports for destination, but when i am scanning from port scanner it shows several tcp ports are enabled.. need your seuggestion and help on it.. how to block these tcp ports..
Early response is required..
Super Bronze
You have not given any configurations to reference or mentioned at all the ports that were open in the scanner.
We would need a bit more information to go on.
- Jouni
Below is the configuration..
access-list extended permit tcp any host ip eq https
access-list extended deny ip any any
Super Bronze
Still don't know the ports that were supposedly open.
Though if that is the ACL you have bound to the "outside" interface on the ASA then it should be blocking the connections through the ASA for everything else other than the TCP/443 for a single destination IP address.
Then there is naturally the ASAs own services and ports on which its listening on.
You can check that with the following command
show asp table socket
Most likely the ports that are open on the ASA are the ones used for management purposes perhaps
Those set with the following commands
telnet
ssh
http
You also have the option to create an ACL that blocks all traffic to the ASA "outside" interface IP address. You can then attach it with "access-group" command
access-group in interface outside control-plane
This would limit the "To the Box" traffic. Though the above mentioned management commands "telnet", "ssh" and "http" would still override this ACL.
- Jouni
98
