Need help opening up some ports for access to internal servers
I have 3 internal MS Server 2003 that need to be accessible from the the outside. The server IP's are 192.168.0.237 needs ports 21095-21096, 192.168.0.240 needs ports 21093-21094 and 192.168.0.242 needs ports 21097-21098. I need to allow all traffic through to those servers on those ports. Here's my config:
ASA Version 7.2(2)
hostname asa5510
domain-name xxxxxxx.com
enable password xxx
names
dns-guard
interface Ethernet0/0
nameif External
security-level 0
ip address 111111111111 255.255.255.248
interface Ethernet0/1
nameif Internal
security-level 100
ip address 11111111111 255.255.255.0
interface Ethernet0/2
nameif DMZ
security-level 80
ip address 192.168.2.1 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
management-only
passwd xxxxxxxxxxxxxx encrypted
boot system disk0:/asa722-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
domain-name xxxxxxxxx.com
access-list External_access_in extended permit tcp any interface External eq 21093
access-list External_access_in extended permit tcp any interface External eq 21094
access-list External_access_in extended permit tcp any eq 21095 interface External eq 21095
access-list External_access_in extended permit tcp any eq 21096 interface External eq 21096
access-list External_access_in extended permit tcp any eq 21097 interface External eq 21097
access-list External_access_in extended permit tcp any eq 21098 interface External eq 21098
access-list External_access_in extended permit tcp any interface External eq smtp
access-list External_access_in extended permit tcp any host 11111111111 eq ftp
access-list External_access_in extended permit tcp any host 11111111111 eq www
access-list External_access_in extended permit tcp any host 11111111111 eq https
access-list DefaultRAGroup_splitTunnelAcl standard permit 192.168.2.0 255.255.255.0
access-list DefaultRAGroup_splitTunnelAcl standard permit 192.168.0.0 255.255.255.0
access-list DefaultRAGroup_splitTunnelAcl_1 standard permit any
access-list xxxxxxxx_splitTunnelAcl standard permit any
access-list dmz_nat0_outbound extended permit ip 192.168.2.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list dmz_in extended permit icmp any any
access-list dmz_in extended permit ip 192.168.2.0 255.255.255.0 host 192.168.0.201
access-list dmz_in extended permit ip 192.168.2.0 255.255.255.0 host 192.168.0.200
access-list dmz_in extended permit ip 192.168.2.0 255.255.255.0 host 192.168.0.202
access-list dmz_in extended deny ip 192.168.2.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list dmz_in extended permit ip any any
access-list winter_splitTunnelAcl standard permit any
access-list Internal_nat0_outbound extended permit ip 192.168.0.0 255.255.255.0 192.168.3.0 255.255.
255.0
access-list yyyyyyyVPN_splitTunnelAcl standard permit 192.168.0.0 255.255.255.0
access-list hhhhhhVPN_splitTunnelAcl standard permit 192.168.2.0 255.255.255.0
access-list External_cryptomap_65535.40 extended permit ip 192.168.0.0 255.255.255.0 192.168.3.0 255
.255.255.0
access-list External_cryptomap_65535.60 extended permit ip 192.168.2.0 255.255.255.0 192.168.3.0 255
.255.255.0
access-list Internal_access_in extended permit icmp any any
access-list Internal_access_in extended permit ip any any
1 ACCEPTED SOLUTION
Green
Re: Need help opening up some ports for access to internal serve
Did you mean to specify source ports in your acl? Without source ports would look like this...
access-list External_access_in extended permit tcp any interface External eq 21095
access-list External_access_in extended permit tcp any interface External eq 21096
access-list External_access_in extended permit tcp any interface External eq 21097
access-list External_access_in extended permit tcp any interface External eq 21098
pager lines 24
logging enable
logging asdm informational
mtu External 1500
mtu Internal 1500
mtu DMZ 1500
ip local pool VPN 192.168.3.1-192.168.3.254 mask 255.255.255.0
ip verify reverse-path interface External
ip verify reverse-path interface DMZ
icmp unreachable rate-limit 1 burst-size 1
icmp permit any External
icmp permit any Internal
icmp permit any DMZ
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat-control
global (External) 1 interface
nat (Internal) 0 access-list Internal_nat0_outbound
nat (Internal) 1 0.0.0.0 0.0.0.0
nat (DMZ) 0 access-list dmz_nat0_outbound
nat (DMZ) 1 0.0.0.0 0.0.0.0
static (Internal,External) tcp interface smtp 192.168.0.202 smtp netmask 255.255.255.255
static (Internal,External) tcp interface 21093 192.168.0.240 21093 netmask 255.255.255.255
static (Internal,External) tcp interface 21094 192.168.0.240 21094 netmask 255.255.255.255
static (Internal,External) tcp interface 21095 192.168.0.237 21095 netmask 255.255.255.255
static (Internal,External) tcp interface 21096 192.168.0.237 21096 netmask 255.255.255.255
static (Internal,External) tcp interface 21097 192.168.0.242 21097 netmask 255.255.255.255
static (Internal,External) tcp interface 21098 192.168.0.242 21098 netmask 255.255.255.255
static (Internal,DMZ) 192.168.0.0 192.168.0.0 netmask 255.255.255.0
static (DMZ,External) 11111111111 192.168.2.4 netmask 255.255.255.255
static (DMZ,External) 11111111111 192.168.2.3 netmask 255.255.255.255
static (DMZ,External) 11111111111 192.168.2.2 netmask 255.255.255.255
access-group External_access_in in interface External
access-group Internal_access_in in interface Internal
access-group dmz_in in interface DMZ
route External 0.0.0.0 0.0.0.0 1111111111111 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
group-policy DfltGrpPolicy attributes
banner none
wins-server none
dns-server none
dhcp-network-scope none
vpn-access-hours none
vpn-simultaneous-logins 3
vpn-idle-timeout 30
vpn-session-timeout none
vpn-filter none
vpn-tunnel-protocol IPSec
password-storage disable
ip-comp disable
re-xauth disable
group-lock none
pfs disable
ipsec-udp disable
ipsec-udp-port 10000
split-tunnel-policy tunnelall
split-tunnel-network-list none
default-domain none
split-dns none
intercept-dhcp 255.255.255.255 disable
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout 30
ip-phone-bypass disable
leap-bypass disable
nem disable
backup-servers keep-client-config
msie-proxy server none
msie-proxy method no-modify
msie-proxy except-list none
msie-proxy local-bypass disable
nac disable
nac-sq-period 300
nac-reval-period 36000
nac-default-acl none
address-pools none
client-firewall none
client-access-rule none
webvpn
functions url-entry
html-content-filter none
homepage none
keep-alive-ignore 4
http-comp gzip
filter none
url-list none
customization value DfltCustomization
port-forward none
port-forward-name value Application Access
sso-server none
deny-message value Login was successful, but because certain criteria have not been met or due to
some specific group policy, you do not have permission to use any of the VPN features. Contact your
IT administrator for more information
svc none
svc keep-installer installed
svc keepalive none
svc rekey time none
svc rekey method none
svc dpd-interval client none
svc dpd-interval gateway none
svc compression deflate
group-policy radical internal
group-policy radical attributes
dns-server value 192.168.0.15
default-domain value xxxxxxxxx
group-policy yyyyyyyVPN internal
group-policy yyyyyyyVPN attributes
dns-server value 192.168.0.201
split-tunnel-policy tunnelspecified
split-tunnel-network-list value DefaultRAGroup_splitTunnelAcl
default-domain value xxxxxxxxx.com
username user1 password sv.wwwwwwwwwww encrypted privilege 15
username user1 attributes
vpn-group-policy yyyyyyyyVPN
vpn-simultaneous-logins 50
username user2 password sv.xxxxxxxxxxxx encrypted privilege 15
username user2 attributes
vpn-group-policy yyyyyyyVPN
http server enable
http 192.168.0.0 255.255.255.0 Internal
http 192.168.2.0 255.255.255.0 DMZ
http 192.168.3.0 255.255.255.0 Internal
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map External_dyn_map 20 set pfs
crypto dynamic-map External_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map External_dyn_map 40 match address External_cryptomap_65535.40
crypto dynamic-map External_dyn_map 40 set pfs
crypto dynamic-map External_dyn_map 40 set transform-set ESP-3DES-SHA
crypto dynamic-map External_dyn_map 60 match address External_cryptomap_65535.60
crypto dynamic-map External_dyn_map 60 set pfs
crypto dynamic-map External_dyn_map 60 set transform-set ESP-3DES-SHA
crypto map External_map 65535 ipsec-isakmp dynamic External_dyn_map
crypto map External_map interface External
crypto isakmp enable External
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 20
crypto isakmp ipsec-over-tcp port 10000
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
tunnel-group DefaultRAGroup ppp-attributes
no authentication chap
no authentication ms-chap-v1
authentication ms-chap-v2
tunnel-group radical type ipsec-ra
tunnel-group radical general-attributes
address-pool VPN
default-group-policy radical
tunnel-group radical ipsec-attributes
pre-shared-key *
tunnel-group new type ipsec-ra
tunnel-group new general-attributes
address-pool VPN
tunnel-group new ipsec-attributes
pre-shared-key *
tunnel-group yyyyyyyVPN type ipsec-ra
tunnel-group yyyyyyyVPN general-attributes
address-pool VPN
default-group-policy yyyyyyyVPN
tunnel-group yyyyyyyVPN ipsec-attributes
pre-shared-key *
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
telnet 192.168.3.0 255.255.255.0 Internal
telnet 192.168.2.0 255.255.255.0 DMZ
telnet timeout 30
ssh timeout 5
console timeout 30
management-access Internal
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 2048
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
inspect icmp error
inspect ipsec-pass-thru
inspect pptp
service-policy global_policy global
ntp server 192.5.41.41 source External
prompt hostname context
What am I missing? Thanks.
Green
I guess I'm not totally clear on what I need to do so I allow all traffic in from the External interface on those ports to the specified server IP's. I guess I'm confused on exactly what source ports is referring too. Could you give me a little schooling on it? Thanks for your help.
Would I need to make any other changes since this is a Windows mobile device that is accessing these servers? They had this working with an old Firebox firewall by just opening those ports to those server IP's. I screwed up the setting and put those source ports in on some settings so I removed them now. Anything else that might prevent the connection? Thanks
Once I removed the ports from the ACL it fixed my problem. Thanks.
Source ports are typically random ports > 1023 and you would rarely specify those. For example, to permit Internet users to reach your web server, you'd allow tcp/any (all source ports) to host ip eq 80.
274
