Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Need help with an object-group on PIX 506
I need to group the following ports for a VoIP device.
514 UDP
1194 UDP
3480 UDP
49000-50000 UDP
443 TCP
I obviously don't want to make 1000+ entries in the PIX config, and I'm a tad confused on the object-group and then how to apply it.
Single IP, translated from the interface to 192.168.1.5. What commands will I need? Thanks so much for any help.
Re: Need help with an object-group on PIX 506
object-group service VOIP_TCP tcp
port-object eq 443
object-gropu service VOIP_UDP udp
port-object eq 514
port-object eq 1194
port-object eq 3480
port-object range 49000 50000
access-list TESTACL permit tcp any any object-group VOIP_TCP
access-list TESTACL permit udp any any object-group VOIP_UDP
is this what you are looking for ?
Community Member
Yes. The config on this PIX is a bit older and using static/conduit commands (I know it's outdated). What is the static command for those port mappings?
sorry mark, I didn't get the static part of your question.
which code are you running btw ?
105
