Need help with PAT translation
I need to do a PAT translation for SMTP. I have a 3rd party company filtering mail for us. I only want to accept mail from there IP on our ASA. Do I need to create a PAT and an ACL?
Also, when I try and set the PAT up I get an error message. The 3rd party company gave me a range of ip addresses (208.65.144.0/21). I?m trying to translate that to my exchange server. The command I am using is ? static (outside,inside) tcp 10.132.13.27 smtp 208.65.144.0 smtp netmask 255.255.248.0
Can I not map a range of outside to a single inside?
Thanks for any help you can give me.
3 ACCEPTED SOLUTIONS
Green
Re: Need help with PAT translation
You need to use a single address and your static is written wrong.
static (inside,outside) tcp 208.65.144.x smtp 10.132.13.27 smtp netmask 255.255.255.255
access-list outside_access_in permit tcp host <3rd.party.ip> host 208.65.144.x eq smtp
access-group outside_access_in in interface outside
Green
That will work fine. Actually it would look like this...
static (inside,outside) tcp interface smtp 10.132.13.27 smtp netmask 255.255.255.255
Green
Sure...
access-list outside_access_in permit tcp host <3rd.party.ip> host 12.104.x.x eq smtp
Please rate helpful posts.
Green
Thanks for your response.
How can I take that range of ip addresses and make this work?
Green
I'm not sure I understand. They are going to send you mail to every address in that whole subnet?
I'm not sure why they gave me a range.
What is I create the pat to look like this-
static (inside,outside) tcp 0.0.0.0 smtp 10.132.13.27 smtp netmask 255.255.255.255
Then set the ACL up to only allow the ISP range to use port 25.
Will that work?
Green
No way, that will not work.
Is 208.65.144.0/21 your range of ip's or is this the range of ip's where your 3rd party will send you mail from?
Sorry, I didn't mean to say ISP. I meant the 3rd party for mail.
Green
Sorry Mike, it just makes no sense to me. I would start by getting back to them and find out what the deal is. You cannot translate a single inside server address to multiple outside addresses.
How about translating the ip address of the outside interface?
static (inside,outside) tcp 12.104.x.x smtp 10.132.13.27 smtp netmask 255.255.255.255
Green
Thank you.
From there can I create an acl to only allow the 3rd party to access port 25?
Green
Sure...
Thanks again. I really appreciate all your help.
Green
No problem, hope everything works out.
148
