Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
need help with RDP access to any host on DMZ from Inside network
deleted fixed
Everyone's tags (4)
1 REPLY
Re: need help with RDP access to any host on DMZ from Inside net
To allow communication from inside to DMZ in this case you use static for the translation:
static (inside,dmz) inside inside netmask 255.255.0.0
And allow the traffic on the ACL:
access-list inside-outbound extended permit tcp any host sftp eq 3389
So, it seems you have the configuration...
If it does not work do the following test:
packet-tracer input inside tcp 1.1.1.1 1025 2.2.2.2 3389
The above will show us if the packets are being dropped by the ASA for some reason.
Assuming 1.1.1.1 is the real IP of the inside host accesing the DMZ host 2.2.2.2
Federico.
879
