Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Need lab recommendation
I want to get me CCNA Security certification and would like your suggestions for a home lab.  I DO NOT want to use GNS3.  Should I get an ASA too?  I learn from hands on and have about 900 to spend on a lab.
Thank you for your ideas!
Michael
PS: I do not have any equipment yet.
1 ACCEPTED SOLUTION
Re: Need lab recommendation
If you have a current CCNA RS lab it will be easier to do an upgrade to CCNA Security.
You'll need a couple of 1841s and 2950 or 2960 switches depending on your budget.
I always check out this site for lab setup/kits:
http://www.certificationkits.com/how-to-ccna-security-lab/
Personally, I've got an ASA 5505, few 1841s, an 8-port 3560 and 2960.
Community Member
Thansk for the information above .
Michael
160
