need reboot everyday !!!
hi
one of my client use ASA 5505 one month.
50 user uses internet via ASA. ASA inside is connect directly cisco switch.
All is fine in day operation but at morning when all employe start work then time not eastablish internet via ASA. then time if ASA reboot then all connection is normal again. so everyday do the job reboot ASA for internet reeastbalish and all day no intruption.
can you help which reason causes the problem its hardware related problem ??
regrads
Biplob
Re: need reboot everyday !!!
well thats not good..
Do you have any tunnels ?
Is this asa as u said only for internet ?
Any troubleshooting you have done ?
can you paste the configs
hi
No tunnel. yes only for internet. I told the client to check duplex is ok with the switch.
thanks
Biplob
waiting for replay.
I dont feel its a ASA problem. But still can conclude without much output ifnormation of the ASA or switch.
I guess you can leave office a bit early one day and try to find out fin out why.
1. Log in to the machine.
2. See if you recive ip address (if dhcp)
3. Ping default gateway (if it is ASA)
4. ping outside interface of asa.
5. ping defauly gateway of asa.
6. ping ip address 4.2.2.2
7. check switch status. "show int status" (if cisco)
let me know if you have any output from asa
140
