Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Need setup help with an ASA 5512
I am trying to setup a Cisco ASA 5512 in a lab for a proof of concept. The software version is 8.6(1)2.Any advice would be much appreciated.
The outside interface can ping the gateway but the inside can not:
Airfield1# ping outside 1.1.1.3
Sending 5, 100-byte ICMP Echos to 1.1.1.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/10 ms
Airfield1# ping inside 1.1.1.4
Sending 5, 100-byte ICMP Echos to 1.1.1.4, timeout is 2 seconds:
Success rate is 0 percent (0/5)
The configuration is as follows:
Airfield1# sh run
: Saved
ASA Version 8.6(1)2
hostname Airfield1
enable password 2KFQnbNIdI.2KYOU encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 1.1.1.4 255.255.255.0
interface GigabitEthernet0/1
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Management0/0
nameif management
security-level 100
ip address 192.168.0.1 255.255.255.0
management-only
banner exec ********************************************************
banner exec ATTENTION!
banner exec THIS IS A DOD COMPUTER SYSTEM. BEFORE PROCESSING
banner exec CLASSIFIED INFORMATION, CHECK THE SECURITY
banner exec ACCREDITATION LEVEL OF THIS SYSTEM. DO NOT PROCESS,
banner exec STORE OR TRANSMIT INFORMATION CLASSIFIED ABOVE
banner exec ACCREDITATON LEVEL OF THIS SYSTEM. THIS COMPUTER
banner exec SYSTEM, INCLUDING ALL RELATED EQUIPMENT, NETWORKS AND
banner exec NETWORK DEVICES (INCLUDES INTERNET ACCESS) ARE
banner exec PROVIDED ONLY FOR AUTHORIZED U.S. GOVERNMENT USE.
banner login ************************************************************
banner login  WARNING!!! This is a U.S. Government Department of Defense Network
banner login
banner login This system is provided only for authorized U.S. Government use.
banner login DOD computer systems may be monitored for all lawful purposes,
banner login
banner login Use of this DOD computer system, authorized or unauthorized,
banner login constitutes consent to monitoring.
banner login
banner login Unauthorized use of this DOD computer system may subject you
banner login to criminal prosecution.
banner login
banner login Evidence of unauthorized use collected during monitoring may be used
banner login for administrative, criminal or other adverse action. Use of this
banner login system constitutes consent to monitoring for all lawful purposes.
banner login
banner login Disconnect IMMEDIATELY if you are not an authorized user!
banner motd *********************************************************
banner motd  WARNING!!! This is a U.S. Government Department of Defense Network
banner motd  Disconnect IMMEDIATELY if you are not an authorized user!
banner asdm *********************************************************
banner asdm  WARNING!!! This is a U.S. Government Department of Defense Network
banner asdm  Disconnect IMMEDIATELY if you are not an authorized user!
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit icmp any any
access-list outside_access_in extended permit icmp any any
pager lines 24
logging asdm informational
mtu management 1500
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) after-auto source dynamic any interface
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 1.1.1.3 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.0.0 255.255.255.0 management
http 192.168.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet 192.168.2.0 255.255.255.0 inside
telnet timeout 5
ssh 192.168.2.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd address 192.168.0.2-192.168.0.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home reporting anonymous prompt 1
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly 12
  subscribe-to-alert-group configuration periodic monthly 12
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:e8add3822edb16f3b25f638d9223c6e7
: end
Airfield1#
1 ACCEPTED SOLUTION
Hi Mathew,
The ASA as a security device will not allow you to ping  a distant interface....
What is a distant interface?
As  an example imagine you are on a host behind the inside interface.. You  will be able to ping the inside interface but you wil NOT be able to  ping the DMZ or outside interface... This because they are distant  interface for the inside host..
There is nothing you can do to change that behavior, this is done as a security meassure by the ASA ( Built-in feature)
By design, Cisco does not allow pinging cross interfaces like that.
According to Cisco's own documentation...
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/trouble.html
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/trouble.html#wp1059645
"For  security purposes the security appliance does not support far-end  interface ping, that is pinging the IP address of the outside interface  from the inside network."
Please rate.
Hi Mathew,
Please rate.
Re: Need setup help with an ASA 5512
Thank you sachinga. I was able to ping across the VPN between hosts. So it looks good.
204
