Need UTM Appliance: Anti-X AND IPS
I'm searching for a product which has Anti-X (Spam and Virus Scanning), HTTPS Scanning, and IPS included.
The ASA only supports one module, Anti-X or IPS. With IOS Routers I can combine both softwarebased, but Contentinspection is only a DNS-Service from Trend Micro.
Isn't there a Cisco product around which combines these features? There are many vendors like Astaro or Watchguard, but I want Cisco!
Thanks!
Re: Need UTM Appliance: Anti-X AND IPS
Regarding ASA, you are right, either you can insert IPS or CSC module, in order to fit in both requirement you may use Cisco-IOS router
for IPS use NMIDS module on the router
for Anti-X(Spam+Virus) Use IOS content filtering on the same router
http://www.cisco.com/en/US/partner/prod/collateral/iosswrel/ps6537/ps6586/ps6643/prod_qas0900aecd804abb06.html
--regards
Correct! But the Contentfilter for IOS doesn't scan for viruses or spam. It's only a DNS RBL service to TrendMicro.
272
