Needs help on NAT
global (outside) 2 interface
nat (inside) 2 access-list dmz
access-list dmz permit ip 21.21.0.0 255.255.0.0
nat (inside) 0 0.0.0.0 0.0.0.0
static(inside,outside) 3.3.3.0 3.3.3.0 netmask 255.255.255.0
static(inside,outside) 3.3.4.0 3.3.4.0 netmask 255.255.255.0
The problem here is I am unable to translate the 21.21.0.0 network to its global interface address.
Is the nat (inside) 0 0.0.0.0 0.0.0.0 the cause for not able to translate? Is it safe to remove this command?
thanks,
  • Firewalling
1 REPLY
Needs help on NAT
Hello Kope,
Yes, that is the cause of the issue, please remove it!
Removing this you will start making translation from the inside of your ASA, that is all that is going to change.
Do rate helpful posts
Julio
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
219
