You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
New to Cisco devices - help with ASA-5510 routing
I am new to using Cisco firewalls. I have an ASA-5510 with a truncated Catalyst-3560 switch. I believe I have the trunk setup correctly and I created VLANs in the switch. Through the ASDM, I created the subinterfaces for each VLAN on the ASA. Now I am trying to get traffic to flow between the VLANs. I have read about security levels and assigned the levels such that the most trusted have the highest level (100). VLANs which need to talk to each other, I kept at the same security level.
On one of the higher trusted interfaces, I have a SysLog server. This computer needs access to the other VLANs in order to query and inspect logs and traffic. How do I give that VLAN/Interface access to the others? Is it inherant because of the higher security level? I believe I need to setup NAT, but not sure how to just allow open access (for now).
Thanks in advance!
Jayesh
  • Firewalling
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: New to Cisco devices - help with ASA-5510 routing
in the asdm you will have a tool called packet tracer could you please run that for traffic from server ip to client ip and paste the results it iwll tell wh
r the traffic is getting dropped
If you are not applying an ACL on the high security interface, then by default the ASA will allow traffic to lower security interfaces.
NATting would be your next step. Make sure if you don't nat the host, that there is a route back to it for the return traffic through the ASA.
I hope it helps.
PK
I posted a follow up to another user's response. I realized that you probably
don't get the notification. Here's my follow up question:
Thanks for the swift replies. Here's what I have, but not sure it is working:
* Server on VLAN 104 with security level of 100    [ip 192.168.10.10]
* Client PC on VLAN 111 with security level of 20 [ip 192.168.129.89]
* NAT translation for server-vlan to client-vlan allowing any on server-vlan to use PAT for 192.168.129.20
* Specific ACL for client PC (192.168.129.89) to get to server (192.168.10.10) allowing ALL ICMP traffic
I am trying to test my setup by pinging client from the server, but to no avail. I am missing something, I am sure.
--Jayesh
you need to enable
same-security-tr permit inter-interface
same-security-tr permit intra-interface
if between diff sec levels enable nat for traffivc from high sec level to low
if you do not want to setup nat use nat exemption on the higher sec level interface and define traffic from high sec level to low sec level in the acl for nat exempt
--Jayesh
disable firewall on client
first see if you can ping the client from the firewall
I am able to ping the client using the Ping utility on the ASDM and specifying the client interface.
I am fairly certain that the client machine is not using a firewall.
I had to first update the ASA/ASDM software. That is now done and I ran the Packet Tracer. I attached pictures and it doesn't show any problems for the 'echo' and 'echo-reply' packets to get through. However, when I run 'ping' from a command line on the server, there is no response.
Thoughts? Thanks.
--Jayesh
Can you attach your current ASA configuration?
1441
