Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Newbie need help ASA5505
This is is my first time trying to bring an ADA5505 into a network. I cannot get internet access - I also want to be able to RDP into the server from the from the outside.  I used the startup wizard in the ASDM software, but still cannot get internet access....I think it has to do with NAT/PAT, but not sure where to go from here to fix this......any help is greatly appreciated - here is the the running-config....we don't need DHCP as we use it on the server and any other suggestions would be appreciated for best practices
1 ACCEPTED SOLUTION
Super Bronze
For Internet access you are lacking the default route from the ASA, add the default route with the correct gateway IP
route outside 0.0.0.0 0.0.0.0
If you are having problems with ICMP then add
policy-map global_policy
class inspection_default
  inspect icmp
  inspect icmp error
For the NAT / Static PAT do the following changes
object network RDP
host 192.168.1.106
no nat (outside,inside) static 192.168.1.106 net-to-net service tcp 3389 3389
nat (inside,outside) static interface service tcp 3389 3389
Notice that the above changes are done under the "object". So first issue the command "object network RDP" to move into the correct configuration mode. Then you will enter the correct source "host" for the "nat" configuration. Finally you will remove the current "nat" command and enter the new "nat" command.
What the new "nat" command will do is do Static PAT (Port Forward) for the internal host 192.168.1.106 and use the public IP address of your "outside" interface because we have used the parameter "interface" in the configuration.
You will naturally also need an "access-list" to permit traffic from the external/public network. The thing to consider here is that do you know the public source IP address where the RDP Connections are coming from? Are you always connecting from the same public IP address? If you do know the source IP address then insert it to the below ACL
access-list OUTSIDE-IN remark Allow RDP connections
access-list OUTSIDE-IN permit tcp host object RDP eq 3389
If you dont know the public source IP address were you connect with RDP then you will have to use the "any" instead of the "host". Though that will naturally open up this port for any public/external user to try connection to your server.  In this case you would add the ACL
access-list OUTSIDE-IN permit tcp any object RDP eq 3389
With either of the above ACLs you will have to attach it to the ASA interface also with the command
access-group OUTSIDE-IN in interface outside
Naturally you also have the option to configure VPN Client on the ASA in which case you get secure access to the internal servers without opening any connections from the external/public network.
Hope this helps
Please do remember to mark a reply as the correct answer if it answered your question.
Feel free to ask more though
- Jouni
Super Bronze
  inspect icmp
  inspect icmp error
object network RDP
host 192.168.1.106
Hope this helps
- Jouni
Community Member
Re: Newbie need help ASA5505
Thank you very much for your patience and help - please check my current work - a few questions:
1) with the outside default route - I see in the outside route it added the number 1 on the end - I think this means default admin distance of 1 hop?
2) I think the RDP needs some more work....do i need to remove this line:
nat (inside,outside) after-auto source dynamic any interface
3) I see under policy_map global_policy it added inspect icmp and inspect icmp error - so this is working? This is for pings out side of LAN?
.....also want to setup VPN, but will need help with that too
Super Bronze
Did the connection to the Internet work after adding the default route? I didnt see anything else that should be a problem.
If you added the needed NAT and ACL Configurations then it should work unless there are some problems on the actual server.
You can try the "packet-tracer" command on the ASA to test its configurations
packet-tracer input outside tcp 12345 3389
Insert that matches the ACL rule you created and insert your public IP address configured on the ASA to the .
Post that output
You should not remove the other "nat" configuration as that is the Dynamic PAT translation for all the LAN users towards Internet.
The ICMP inspections are basically meant to automatically allow the ICMP Echo reply back to the host on the LAN if it sends ICMP to something on the Internet.
For VPN you would have to either use the old Cisco IPSec VPN Client or Cisco AnyConnect Client depending if you have the software for that on the ASA. The actual configuration is probably best done through the Wizard and if it doesnt work then we could look at the configuration again.
- Jouni
Silver
It could be related to that you need to define ipv4 on the ACL but please run the packet tracer it should tell us
Value our effort and rate the assistance!
Community Member
OK - I dropped it in an everything seems to be working.....I have internet and I can RDP in from the outside.....but packet tracer is failing from the ASDM....it does pass when run from the command line .......I have attached current config
Super Bronze
What did you add?
If the "packet-tracer" goes through from the CLI and not from the ASDM then you have probably given some wrong information on the ASDM Side in its GUI.
Main thing is that connection are working. Atleast I understood so from your reply?
- Jouni
Community Member
yes - we are working - thanks....for the packet tracer in ADMN:
For interface - select outside
Source IP - my public IP address
Source port - 12345
Destination IP: 192.168.1.106
Destination port: 3389
Is this correct?
Super Bronze
No, it should be
  • Source IP: 1.1.1.1 (for example)
  • Destination IP: your public IP
Please remember to mark a reply as the correct answer if it answered your question and rate helpfull answers
Though naturally ask more if there is still something that needs looking into.
- Jouni
Community Member
That was it - it worked correctly - thanks again.  I want to study some more before I attempt the VPN setup - I will open a new thread when I am ready to start - or fail
Super Bronze
Ok, lets look at the VPN setup if needed when you have had time to set it up.
- Jouni
281
