No class inspection_default on 5505?
I was under the impression that all Cisco ASA firewalls shipped with a default inspection policy.
Example
policy-map global_policy
  inspect dns preset_dns_map
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect http
  inspect ipsec-pass-thru
However, looking at a 5505 I have here, there is NO default inspection policy defined. If I try to add
It tells me there is no class inspection_default
can I build this myself? Why is it missing (I have two other ASA 5505s here that also do not have it). What would I do to rebuild it?
Everyone's tags (1)
Ah, nevermind: figured out what the issue was
you need the
class-map inspection_default
 match default-inspection-traffic
Hello Collin,
When there is no inspection default, you can also add "Clear config fixup" and the default policy will appear.
Mike
Mike
clear config fixup is a nifty
clear config fixup is a nifty trick.
Thank you!
1739
