No connection to the outside from ASA 5510
I have just put an ASA5510 in place and have the following setup:
Interface Ethernet0/0
    nameif outside
    security-level 0
    ip address dhcp setroute
Interface Ethernet0/1
    nameif inside
    security-level 100
    ip address 192.168.15.1 255.255.255.0
dhcpd address 192.168.15.40-192.168.15.254 inside
dhcpd enable inside
I have connected my stations to an ESW540 inside of the Int Eth0/1 and am able to get ip addresses to the stations as well as DNS addresses.  I cannot however connect to the outside connection in any way.  From a computer connected to the ESW540 with a DHCP assigned IP address, I can ping the computer's IP, the ESW540's IP, and even 192.168.15.1.  But I cannot ping the ip address from the Int Eth0/0, nor anything beyond 192.168.15.1.
From inside of the console of the ASA, I can ping all addresses of all ports as well as devices outside of the building and inside of ESW540.  I guess I am just at a loss of what to do next.  Any help would be appreciated.
Respectfully,
me
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hello Ronald,
Here are the reasons why this is not working?
1- You cannot ping a distant interface, this as a security approach from the ASA.
Example: 192.168.10.1----asa------211.1.1.1-------211.1.1.1Router----Internet
From the 211.1.1.1 network you would be able to ping the directed connected interface (211.1.1.1) but you will not be able to ping the inside interface no matter what.
Same thing would happen from the inside. you will be able to ping outside ip addresses except the ip address of the Outside interface of the ASA.
2-ICMP protocol is not statefully inspected by the ASA by default.
Example: 192.168.10.1----asa------211.1.1.1-------211.1.1.1Router----Internet----4.2.2.2
Ping from 192.168.10.2 to 4.2.2.2
When you try to ping the ICMP request will go to the inside interface, then it will go out to the outside interface going to the destination, the ICMP reply will come to the outside interface and unless there is an ACL allowing the communication the packet will be dropped but do not worry there is an option to statefully inspect the ICMP protocol and this is the Inspect ICMP command.
     - Fixup protocol ICMP
3-You will need to nat the inside users in order to be able to reach outside (Internet hosts)
Nat (inside)  1 0 0
global  (outside) 1 interface
Hope this helps,
Please do rate helpful posts,
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hall of Fame Super Silver
We'd need more than the 1/10th of your ASA config you posted above to weigh in with any substantive suggestions. Can you post your whole configuration (sanitized)?
First questions that come to my mind are:
Why would you not make your outside interface static? What are your NAT rules? ACLs? etc., etc.
Sorry for the information underload.
Our ISP is currently providing our external IP address via DHCP.  They will not be able to change that until after Christmas.  Here is the config file as it stands.
ASA Version 8.2(1)
hostname ciscoasa
enable password
passwd
names
interface Ethernet0/0
nameif outside
security-level 0
ip address dhcp
interface Ethernet0/1
nameif inside
security-level 100
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
access-list 101 extended permit icmp any any
access-list 101 extended permit ip any any
access-list any extended permit ip any any
pager lines 24
logging asdm informational
mtu management 1500
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
access-group any in interface outside
access-group any in interface inside
route outside 0.0.0.0 0.0.0.0 98.101.250.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet 192.168.1.0 255.255.255.0 management
telnet 192.168.15.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username rlsj password CzwimrfqLMj7M0Ua encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:56f11d20d06789d8caa1e1e56a4bcf95
Hello Ronald,
Can you check my post, there is what you are missing on your config,
Do rate helpful posts.
Julio
Julio Carvajal
Hello Ronald,
Nat (inside)  1 0 0
Hope this helps,
Julio
Julio Carvajal
The level of genius here is AWESOME!  Thanks for your help.  It's the smallest things that kill me.
Thanks again!
Hello Ronald.
Thanks for the comments and the rating.
It is great to hear that now everything is working as expected, any other question I would be more than glad to help.
Hope you have a great day,
Julio
Julio Carvajal
818
