No matching connection for ICMP error
I'm seeing this on our cisco pix 515e firewall log quite often:
Sep  1 13:42:52 192.168.120.248 %PIX-4-313005: No matching connection for ICMP error message: icmp src guest:192.168.0.10 dst outside:8.8.8.8 (type 3, code 3) on guest interface.  Original IP payload: udp src 8.8.8.8/53 dst 192.168.0.10/52456.
on the firewall we have this set:  ip address 192.168.0.248 255.255.255.0
access-list guest-out extended permit icmp 192.168.0.0 255.255.255.0 any
access-list guest-out extended permit icmp 192.168.0.0 255.255.255.0 any echo
access-list guest-out extended permit icmp 192.168.0.0 255.255.255.0 any echo-reply
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
  inspect icmp
mtu guest 1500
on a layer 3 switch we have this set:
ip dhcp pool guest_wifi_pool
 network 192.168.0.0 255.255.255.0
 default-router 192.168.0.248
 dns-server 8.8.8.8 8.8.4.4
interface Vlan2
 ip address 192.168.0.1 255.255.255.0
then we have unifi access points in this switch. so far the source ips in the error message seem to be iphones!
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi,Any reason why your IP
Any reason why your IP phone initiates the traffic for 8.8.8.8 ? can you check on the settings of ip phone and make sure it is as per your requirement....
Type 3 – Destination Unreachable
Code 3 - Destination port unreachable
for dns to work..... you need to allow domain in access-list.
access-list guest-out extended permit udp 192.168.0.0 255.255.255.0 host 8.8.8.8 eq domain
access-list guest-out extended permit udp 192.168.0.0 255.255.255.0 host 8.8.4.4 eq domain
also you need to allow the echo-reply for this on inbound acl (outside) interface.
any to 192.168.0.0 - echo-reply
Silver
Hi  parisvcisco It looks like
the IP 192.168.0.10 is trying to use the DNS server (53) of the IP 8.8.8.8  and the ASA captures the destination is unreachable  (Type 3 ) and the port requested is unreachable (code 3).
It might be an application on the device or that the ASA could be dropping the request for security reasons.
I would suggest you to place a capture  on the inside and verify this  a DNS request and see which application might be causing this behavior.
Hope this helps !
- Randy -
Yes on the switch I have set
Yes on the switch I have set the DNS server to be 8.8.8.8 and 8.8.4.4 for that vlan. Do I need to do something on the firewall to allow this?
Silver
Hi ,  And the DNS service
Hi ,
And the DNS service works fine ?
It looks like the ASA is not able to reach the DNS sometimes , can you check if the ASA is dropping the service.
I suggest you to place an ASP capture,
Example :
Capture drop interface inside type asp-drop all
Wait a couple of seconds or start manually the DNS service (request)
And check the capture : Show capture drop | incl 53
Also check on the service policy if the DNS has the inspection enable.
Hope this help
Please rate helpful post !
- Randy -
I don't have type available..
I don't have type available......
# capture drop interface inside ?
  access-list      Capture packets that match access-list
  buffer           Configure size of capture buffer, default is 512 KB
  circular-buffer  Overwrite buffer from beginning when full, default is
                   non-circular
  ethernet-type    Capture Ethernet packets of a particular type, default is IP
  headers-only     Capture only L2, L3 and L4 headers of packet without data in
                   them
  match            Capture packets matching five-tuple
  packet-length    Configure maximum length to save from each packet, default
                   is 68 bytes
  real-time        Display captured packets in real-time. Warning: using this
                   option with a slow console connection may result in an
                   excessive amount of non-displayed packets due to performance
                   limitations.
  trace            Trace the captured packets
fyi this is a cisco pix 515e so pretty old!
I was able to run this
I was able to run this:
capture asp type asp-drop all
# show capture asp | inc 8.8.8.8
327: 09:00:10.672618 802.1Q vlan#2 P0 192.168.0.25 > 8.8.8.8: icmp: 192.168.0.25 udp port 52444 unreachable
We have icmp permit any outside but would icmp permit any guest work/help?
not ip phones just iphones!so
so vlan 2 is for the guest wifi and I want them to use Google's dns servers for DNS.
so on the switch that's doing the routing I have set:
Do I still need to do the steps have you have posted?
Hi, Yes.... on your guest
Yes.... on your guest connected interface you need to allow dns (domain) udp - 53 from guest lan to 8.8.8.8 / 8.8.4.4.
And if you want to allow icmp access to those dns servers for checking or testing then you need to allow echo on guest connected interface acl and echo-reply on outside interface acl...
Karthik
 at the moment i have access
access-group guest-out in interface guest
do i need to do
access-group guest-in in interface guest
then
access-group guest-in any to 192.168.0.0 - echo-reply
nope.... Please send me your
nope....
Please send me your configuration file.... hide out the sensitive information and send me to this post or to the private message... i will suggest you on that..
Karthik
692
