No output for show sip in ASA5515?
 At the firewall ASA5515 I see that sip packets are being inspected but the 'show sip' command gives 0 output.
Below is the output
Result of the command: "show service-policy inspect sip"
Global policy:
  Service-policy: global_policy
    Class-map: inspection_default
      Inspect: sip , packet 2795, lock fail 0, drop 0, reset-drop 0, v6-fail-close 0
               tcp-proxy: bytes in buffer 0, bytes dropped 0
Result of the command: "sh sip"
Total: 0
Any explanation is appreciated.
1 ACCEPTED SOLUTION
Hi   "show sip" command is
"show sip" command is used to display the established SIP sessions across the ASA. It may happen that the SIP traffic is being generated and is getting inspected too, but "show sip" only displays data when there is a established sip session only.
Further to check for sip traffic across firewall you can use:
show service-policy
show local-host | in 5060
debug sip
So if you need any output in "show sip" please verify that there is a established sip session across firewall.
please rate if useful
Cheers
Naveen
Hope it helps Cheers, Naveen Please Rate Helpful posts.
show service-policy
debug sip
Cheers
Naveen
Thanks for the reply Naveen.I
I do see few sip sessions but very rarely. Considering around 15 people using softphones I was expecting significant sip sessions at any given time. Yet I hardly see any in ' sh sip' output. Did a wireshark capture on the FW for one of the PCs and it showed sip traffic.
I don't understand. Is that how its supposed to be?
21
