Hello folks,
I am new to FWSM and looking for some help to fix the outbound connection from one server in VLAN 20 (10.120.20.90) to outside.
Following are the ACL found in the FWSM and connection status when i telnet from the box (10.120.20.90) to outside IP 99.87.209.150 at port 25
Please help me to fix this.
config of FWSM
object-group service i316-services
service-object icmp echo
service-object tcp eq smtp
service-object udp eq domain
service-object tcp eq domain
service-object udp eq snmp
service-object tcp eq 1248
service-object tcp eq 3389
service-object tcp eq 9997
service-object tcp eq 8089
service-object tcp eq 2547
service-object tcp eq 12547
object-group network i316-ext-hosts
network-object host 205.141.238.233
network-object host 205.141.238.171
network-object host 207.239.83.246
network-object host 65.46.63.114
network-object host 216.183.80.178
network-object host 99.87.217.32
network-object host 92.41.19.54
network-object host 99.87.209.50
network-object host 99.87.209.27
network-object host 99.87.209.28
network-object host 99.87.209.29
network-object host 99.87.209.30
network-object host 99.87.209.31
network-object host 99.87.209.150
object-group network i316-int-mgmt-w2k
network-object host 10.120.20.88
network-object host 10.120.20.90
network-object host 10.120.20.92
object-group service i316-backup-server-ports
service-object tcp eq 8086
service-object tcp eq 8087
service-object tcp eq 2546
access-list i316-in extended permit ip any any
access-list i316-in extended permit ip host 10.120.20.89 10.120.146.0 255.255.255.0
access-list i316-in extended permit tcp host 10.120.20.89 any eq domain
access-list i316-in extended permit udp host 10.120.20.89 any eq domain
access-list i316-in extended permit udp host 10.120.20.89 any eq ntp
access-list i316-in extended permit tcp host 10.120.20.89 any eq smtp
access-list i316-in extended permit tcp host 10.120.20.90 any eq www
access-list i316-in extended permit tcp host 10.120.20.90 any eq https
access-list i316-in extended permit tcp host 10.120.20.90 any eq 9997
access-list i316-in extended permit object-group i316-services object-group i316-int-mgmt-w2k any
access-list i316-in extended permit object-group i316-services object-group i316-int-mgmt-w2k object-group i316-ext-hosts log
global (outside) 1 interface
nat (i316) 1 10.120.20.0 255.255.255.0
access-group i316-in in interface i316
interface Vlan20
nameif i316
security-level 100
ip address 10.120.20.2 255.255.255.0 standby 10.120.20.8
Default gateway of FWSM is outside IP 203.140.205.1
FWSM# sh conn | inc 99.87
TCP outside 99.87.209.150:25 i316 10.120.20.90:3109 idle 0:00:09 Bytes 132 FLAGS - S
TCP outside 99.87.209.30:9997 i316 10.120.20.90:3108 idle 0:00:14 Bytes 132 FLAGS -
TCP outside 99.87.209.150:25 i316 10.120.20.90:3109 idle 0:00:15 Bytes 132 FLAGS - S
TCP outside 99.87.209.27:9997 i316 10.120.20.90:3114 idle 0:00:01 Bytes 132 FLAGS -
ROUTE STATUS OF THE WINDOWS BOX (10.120.20.90)
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 10.120.20.2 10.120.20.90 10
10.120.20.0 255.255.255.0 10.120.20.90 10.120.20.90 10
10.120.20.90 255.255.255.255 127.0.0.1 127.0.0.1 10
10.255.255.255 255.255.255.255 10.120.20.90 10.120.20.90 10
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
224.0.0.0 240.0.0.0 10.120.20.90 10.120.20.90 10
255.255.255.255 255.255.255.255 10.120.20.90 10004 1
255.255.255.255 255.255.255.255 10.120.20.90 10005 1
255.255.255.255 255.255.255.255 10.120.20.90 10.120.20.90 1
Default Gateway: 10.120.20.2
Persistent Routes:
None
