not able to connect ASA thru ASDM
I'm not able to connect ASA thru ASDM from outside n/w the error is
"ASDM is unable to read the configuration from the ASA. please check the
configuration & your connection and then try again by clicking the refresh icon."
but able to connect from inside n/w
1 ACCEPTED SOLUTION
Re: not able to connect ASA thru ASDM
Two things you should try:
Try from another computer that has an older version of the Java client.
OR
Try to uninstall the update that you just installed.
Usually if ASDM doesn't work, it's because of a java update.
HTH,
John
*please rate if helpful*
HTH, John *** Please rate all useful posts ***
Did you allow your public address into the ASA?
http outside
HTH,
John
ya all these days it was working, but all of sudden its not working 2day
Have you updated Java recently? Can you access it from a different system?
yes, i have updated the java 2day only.
below is the version i have now in my pc.
J2SE runtime env 5.0
Java(TM)6 update 11
Java(TM)6 update 7
OR
HTH,
John
John,
Its working
I have uninstalled the update
384
