Not able to connect from outside IP
Hi, the Firewall configuration is attached
When I try to access by remote desktop from outside IP to 196.44.242.51 Server (vrw-appdb-001) then I am not able to connect. Please check above config if you find anything wrong then please let me know.
Re: Not able to connect from outside IP
Hi ray
Please rate the posts which helped you in the previous questions you have asked. Rating does not cost any fee.
http://forums.cisco.com/eforum/servlet/NetProf?page=help_rating
Ray,
Am I understanding right, you are not able to Remote Desktop (RDP) into the network from APPDB?
***Edit***
I see what you're saying now.
Ray,
I am able to connect to the said server via Remote Desktop just fine. The problem is possibly on your side.
On a security note.. I would suggest an alternate approach to allowing access like this. You might want to think about possibly a VPN account and using that to access these devices. Leaving them open to the world over these protocols is extremely dangerous.
Anyway, best of luck!
hi there
U r using a wrong command for connecting the outside
access-list vrw-vpn-001_splitTunnelAcl standard permit 192.168.50.0 0.0.0.255
access-list vrw-vpn-001_splitTunnelAcl standard permit 192.168.51.0 0.0.0.255
here u use a subnet mask u have to use a wild card mask
try this command once
thanks
102
