Not able to do tracert on ASA5510
lawsuites
Have ASA5510 and first thing i like to is to open tracert so please  help with entry.
Also our connection is not stable and  sometimes connection goes down or some sites don't open up.  As you go  through the configs you can see it's hard-coded with 1000/full and the  router 1841 that attached to this 10/100.  Can this be issue that  connection is not stable and also can we remove 1000/full coded and set to auto-negotiate.
Jennifer Halim
You would also need to add the following:
access-list 100 permit icmp any any
icmp unreachable rate-limit 50 burst-size 6
class-map decrement-ttl-class
     match any
policy-map global_policy
  class inspection_default
     inspect icmp error
  class decrement-ttl-class
   set connection decrement-ttl
Hope that helps.
12 Replies 12
Jennifer Halim
     match any
     inspect icmp error
Hope that helps.
thank you very much halijenn.
Can you also give me any advise on our connection issue:
"Also our connection is not stable and  sometimes connection goes down or  some sites don't open up.  As you go  through the configs you can see  it's hard-coded with 1000/full and the  router 1841 that attached to  this 10/100.  Can this be issue that  connection is not stable and also  can we remove 1000/full coded and set to auto-negotiate."
Yes, I would suggest that you change it to auto negotiate on both end, ie: the ASA interface as well as the switch/router interface connected to it.
Halijenn that's whrere i am weak at.  Can you please give me the entries how to to do that, i don't want to make any mistakes. Thanks you again you have helped me alot.
Is it connected to the router directly, or through a switchport?
Here is the configuration on the ASA:
interface Ethernet0/1
  speed auto
  duplex auto
Please also make sure that you configure the same on the switch port or router port which is connected to the ASA eth0/1 interface.
With you're help i am able to tracert and able to fix the 1000/full.
one issue since i made the changes speically with tracert suddnelly my Blackberry stop syncing with our server.  I can't send or recive email.  Does that have to do anything with these changes.
"access-list 100 permit icmp any any
     match any
     inspect icmp error
   set connection decrement-ttl"
Great to hear both issues are resolved. Please kindly mark question answered and rate.
I don't believe the tracert changes impacted the Blackberry communication.
You can try removing the following and see if that resolves the Blackberry communication:
     no class decrement-ttl-class
If that doesn't fix the Blackberry comm, you can place the configuration back in:
Hope that helps.
thanks will do that.  sorry to keep bothering you one more question: on tracert the second hop in middle it's lap(i think)...can you advise
Tracing route to google.com [66.249.91.104]
over a maximum of 30 hops:
  1    <1 ms     1 ms    <1 ms  ..dell switch ip
  2    <1 ms     *       <1 ms  xx.xxx.xxx. ...is this an issue.  (this ip comes in on asa5510 config on first eithernet 0/0 ..wire is connected with asa5510 and cisco 1841)
  3     2 ms     2 ms     2 ms  gi0-3.na31.b002958-0.jfk01.atlas.cogentco.com [x
x.xxx.xxx.xx)
  4    <1 ms    <1 ms    <1 ms  gi1-46.3929.mpd01.jfk01.atlas.cogentco.com [xx.x
x.xx.253]
  5     1 ms    <1 ms    <1 ms  te0-3-0-7.mpd22.jfk02.atlas.cogentco.com [154.54
.1.209]
  6     1 ms     1 ms     1 ms  te4-7.mpd01.jfk05.atlas.cogentco.com [154.54.6.5
0]
  7     1 ms     1 ms     1 ms  te1-1.ccr02.jfk05.atlas.cogentco.com [154.54.3.1
61]
  8     1 ms     1 ms     1 ms  core1-0-0-8.lga.net.google.com [198.32.118.39]
  9     1 ms     1 ms     1 ms  209.85.248.180
10     1 ms     1 ms     1 ms  209.85.241.148
11     1 ms     1 ms     1 ms  lga15s02-in-f104.1e100.net [66.249.91.104]
Sorry, can you please clarify your question on the ASA hop? I don't quite understand what you are trying to ask.
As you can see on tracert..first hop is fine (that is our dell switch), second hope which connect with our firewall(asa5510)
have * in the middle rather then number....i asking is there packet drop or connection drop when connection go through our firewall
second hope is like this   2    <1 ms     *       <1 ms  xx.xxx.xxx.(firewall ip)
Sorry to keep bothering you...one more question...since i made the change for tracert and 1000/full...outlook outgoing message start getting stuck in queu (on server)...is this some how releted to this entry.....
i removed the 1000/full on 0/1 ethernet and made it auto...this line is connected with firewall to our dell switch...any suggestion....
Dont' think the mail issue is related. Unless that particular interface that you change to auto negotiate didn't negotiate to the right speed and duplex.
You can hard code it to the same speed on both the ASA interface and the Dell switch interface. Just make sure that they are exactly the same. Prior to the change, your switch is on 10/100 while the ASA is on 100/1000 and you have manually hard coded it to 1000 hence it's not matching.
