Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Not able to ping ASA standby interface over l2l VPN
I have a pair of ASA's 5525-X in an active/standby setup on a remote office location. I wish to monitor the inside interfaces on this devices. From the head office I have an l2l IPsec tunnel to the remote site from another ASA firewall. From a host on my head office network I'm able to ping the inside ip interface on the active 5525-X, but I'm not able to ping the inside interface on the standby unit. With packet tracer I can see that the ICMP echo request packet is leaving the active unit's inside interface and also see that this packet arriving on the standby unit inside interface. But I never see an echo reply from the standby unit - on any interfaces.
I’m also able to ping other hosts on the remote office lan.
Ping from host PC in head office:
C:\Users\zen>ping 10.0.60.1
Pinging 10.0.60.1 with 32 bytes of data:
Reply from 10.0.60.1: bytes=32 time=24ms TTL=248
Reply from 10.0.60.1: bytes=32 time=23ms TTL=248
Reply from 10.0.60.1: bytes=32 time=28ms TTL=248
Ping statistics for 10.0.60.1:
   Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
   Minimum = 23ms, Maximum = 28ms, Average = 25ms
C:\Users\zen>ping 10.0.60.2
Pinging 10.0.60.2 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.0.60.2:
   Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
ASA inside interface config:
interface Port-channel20
  nameif inside
  security-level 100
  ip address 10.0.60.1 255.255.255.0 standby 10.0.60.2
No NAT for VPN traffic:
nat (inside,outside) source static obj-10.0.60.0 obj-10.0.60.0 destination static obj-192.168.200.0 obj-192.168.200.0 no-proxy-arp route-lookup
Packet trace on ASA standby unit:
ASA/sec/stby# sh capture
capture egress type raw-data packet-length 1522 [Capturing - 0 bytes]
match icmp host 10.0.60.2 any
capture ingress type raw-data packet-length 1522 interface inside [Capturing - 180 bytes]
match icmp any host 10.0.60.2
ASA/sec/stby# sh capture ingress
5 packets captured
   1: 15:30:05.675090       192.168.200.23 > 10.0.60.2: icmp: echo request
   2: 15:30:10.682703       192.168.200.23 > 10.0.60.2: icmp: echo request
   3: 15:30:15.674922       192.168.200.23 > 10.0.60.2: icmp: echo request
   4: 15:30:20.682398       192.168.200.23 > 10.0.60.2: icmp: echo request
5 packets shown
ASA/sec/stby#
The ASA's is running Cisco Adaptive Security Appliance Software Version 9.1(1)
Thank You
/Peter
What about translating the traffic on the local ASA (Active unit) for traffic received from the VPN tunnel to the internal interface IP address? You can try something like nat (outside,inside) source dynamic obj-VpnRemoteTraffic interface destination static StandbyIP StandbyIP
Were you able ro resolve the
Were you able to resolve the issue?
197
