not able to ping from router to outside interface of the Firewall
We are facing one issue here, the issue is
from router to firewall interface IP i.e. inside interface ip I can ping , but not the outside IP address i.e. 122.160.225.190
from out side i.e. from external network I can ping the outside interface ip of the firewall i.e. 122.160.225.190
I need to ping the & users need to browse the internet. Please provide me the solution
please can you let me know what could be the problem.attached the ASA config , router config & Network Diagram for your reference. if not please provde the config for this setup.
thanks in advance
padmanabha
regards
Re: not able to ping from router to outside interface of the Fir
try this commands -
policy-map global_policy
class inspection_default
inspect icmp
Hope this helps.
this command is enabled default in the Firewall.
i need router pakcets reach the outside interface of the firewall . i.e internet
Hi Pad,
***There are some configurations on the router you may need to remove, they are the nat configuration below is the how to do so:
interface FastEthernet0/0
no ip nat outside
exit
no interface FastEthernet0/0.63
interface FastEthernet0/1
no ip nat inside
exit
no ip nat pool internet 122.160.227.185 122.160.227.186 netmask 255.255.255.248
***also on the firewall make the following configurations:
icmp permit any inside
icmp permit any outside
no interface Ethernet0/0.63
interface ether 0/0
nameif outside
ip address 122.160.225.190 255.255.255.252 "put the ASA outside ip here"
no shut
no route outside 0.0.0.0 0.0.0.0 122.160.225.190
route outside 0.0.0.0 0.0.0.0 122.160.225.189
no route inside 0.0.0.0 0.0.0.0 10.0.2.1 2
no global (outside) 1 122.160.225.189
global (outside) 1 interface
this will work fine. and please update me.
Best regards,
Mohammed Moustafa.
Hi mohammed,
thanks for the reply, i will re config the both device & let u know the result
Gold
icmp inspection might be enabled, but it's not enabled by default.
also, you cannot ping the far side interfaces of a pix/asa - this is by design and cannot be changed. you can only ping the interface closest to the pinging host.
135
