Not able to ping natted I.P from inside
we are using ASA5505 having two interfaces inside(Security level 100) outside (security level 50)
We had statically natted I.P X.X.X.X (inside ) to Y.Y.Y.Y (Public I.P).We are able to ping this public I.P from Internet ,also nat is working successfully.
we are able to ping natted I.P from ouside i.e Y.Y.Y.Y but we are not able to ping it from inside .
below is the configuration done
static (inside,outside) Y.Y.Y.Y X.X.X.X netmask 255.255.255.255
Ajay
Bronze
Re: Not able to ping natted I.P from inside
hello,
i maybe wrong but how could you even ping this natted ip from outside to inside, whereas my understanding says that pix doesn't allow any icmp traffic espacially if coming from higher security interface to lower security interface.
Thanks for your reply
My problem has been resolved .
Ajay
Bronze
hello,
you are always welcome, but if you don't mind i would really like to know how you solved it.
We are having the exact same problem.
Could you elaborate on how you solved this issue.
Thank you
Green
Steve, could you elaborate on your problem? How many interfaces are we talking about here? Give us a little more info.
For example if you have 3 interfaces and have
static (dmz,outside) 1.1.1.1 172.16.1.1 netmask 255.255.255.255
You can ping 1.1.1.1 from outside but not from the inside. You would need to add something like this if you wanted to do so....
static (dmz,inside) 1.1.1.1 172.16.1.1 netmask 255.255.255.255
Here are a few options for 2 interfaces
1. dns doctoring
2. hairpinning
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807968d1.shtml
Please rate helpful posts
Well, I guess I got a little trigger happy and sent off this post before reading trough all posts.
I got my answer here
ns&loc=.1dde631e/4&forum=Security&topic=Firewalling
Green
Could you post that link again. Was it the same solution as I posted above?
142
