Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Not Able to ping the Host from Inside Interface From PIX525
When iam tried to upgrading PIX525  6.3 to  7.0 , Not able to Ping the    host from the PIX 525 Inside interface  which is on the same subnet,  Also from the host to Inside Interface ,  Tried with Directly connected  laptop with Cross cable and using Straight cable via switch, But the  results end with fail.
Red
Do you have a show tech from the time you upraded the firewall to version 7.0??
Can you share that?
Varun
Thanks, Varun Rao Security Team, Cisco TAC
Hi Varun
I have attached the Sh tech-Support
sh tech support
Cisco PIX Firewall Version 6.3(3)
Cisco PIX Device Manager Version 3.0(1)
Compiled on Wed 13-Aug-03 13:55 by morlee
FW-CORP up 3 hours 12 mins
Hardware:   PIX-525, 256 MB RAM, CPU Pentium III 600 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is 000f.34d8.3c18, irq 10
1: ethernet1: address is 000f.34d8.3c19, irq 11
2: ethernet2: address is 000d.88ee.1168, irq 11
3: ethernet3: address is 000d.88ee.1169, irq 10
4: ethernet4: address is 000d.88ee.116a, irq 9
5: ethernet5: address is 000d.88ee.116b, irq 5
Licensed Features:
Failover:                    Enabled
<--- More --->
VPN-DES:                     Enabled
VPN-3DES-AES:                Enabled
Maximum Physical Interfaces: 8
Maximum Interfaces:          12
Cut-through Proxy:           Enabled
Guards:                      Enabled
URL-filtering:               Enabled
Inside Hosts:                Unlimited
Throughput:                  Unlimited
IKE peers:                   Unlimited
This PIX has a Failover Only (FO) license.
Serial Number: 808092851 (0x302a84b3)
Running Activation Key: 0x51f05806 0x46615259 0xd47d04a4 0x6de07c80
Configuration last modified by enable_15 at 16:24:11.001 IST Tue Jan 24 2012
------------------ show clock ------------------
16:27:16.954 IST Tue Jan 24 2012
<--- More --->
------------------ show memory ------------------
Free memory:       205886928 bytes
Used memory:        62548528 bytes
Total memory:      268435456 bytes
------------------ show conn count ------------------
0 in use, 0 most used
------------------ show xlate count ------------------
------------------ show blocks ------------------
  SIZE    MAX    LOW    CNT
     4   1600   1600   1600
<--- More --->
    80    400    399    400
   256   1012   1008   1012
  1550   2469   1691   1700
------------------ show interface ------------------
interface ethernet0 "outside" is up, line protocol is down
  Hardware is i82559 ethernet, address is 000f.34d8.3c18
  IP address 210.212.241.66, subnet mask 255.255.255.224
  MTU 1500 bytes, BW 100000 Kbit full duplex
    0 packets input, 0 bytes, 0 no buffer
    Received 0 broadcasts, 0 runts, 0 giants
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
    0 packets output, 0 bytes, 0 underruns
    0 babbles, 0 late collisions, 0 deferred
    0 lost carrier, 0 no carrier
    input queue (curr/max blocks): hardware (128/128) software (0/0)
    output queue (curr/max blocks): hardware (0/0) software (0/0)
interface ethernet1 "inside" is up, line protocol is down
<--- More --->
  Hardware is i82559 ethernet, address is 000f.34d8.3c19
  IP address 172.16.24.3, subnet mask 255.255.252.0
    480 packets output, 28800 bytes, 0 underruns
    output queue (curr/max blocks): hardware (0/2) software (0/1)
interface ethernet2 "WAN" is up, line protocol is down
  Hardware is i82559 ethernet, address is 000d.88ee.1168
  IP address 172.16.9.1, subnet mask 255.255.255.0
<--- More --->
interface ethernet3 "DMZ" is up, line protocol is down
  Hardware is i82559 ethernet, address is 000d.88ee.1169
  IP address 172.16.8.1, subnet mask 255.255.255.0
interface ethernet4 "intf4" is administratively down, line protocol is down
  Hardware is i82559 ethernet, address is 000d.88ee.116a
<--- More --->
  MTU 1500 bytes, BW 10000 Kbit half duplex
interface ethernet5 "intf5" is administratively down, line protocol is down
  Hardware is i82559 ethernet, address is 000d.88ee.116b
<--- More --->
------------------ show cpu usage ------------------
CPU utilization for 5 seconds = 0%; 1 minute: 0%; 5 minutes: 0%
------------------ show process ------------------
    PC       SP       STATE       Runtime    SBASE     Stack Process
Hsi 001eaa09 00a6ee14 00555860          0 00a6de8c 3404/4096 arp_timer
Lsi 001effad 00b3203c 00555860          0 00b310c4 3928/4096 FragDBGC
Lwe 00119abf 00bb575c 00558fc0          0 00bb48f4 3688/4096 dbgtrace
Lwe 003e3f55 00bb78ec 0054e188          0 00bb59a4 6648/8192 Logger
Hwe 003e80d0 00bba9e4 0054e438          0 00bb8a6c 8024/8192 tcp_fast
Hwe 003e8049 00bbca94 0054e438          0 00bbab1c 8024/8192 tcp_slow
Lsi 003006f9 02a9cb84 00555860          0 02a9bbfc 3944/4096 xlate clean
Lsi 00300607 02a9dc24 00555860          0 02a9ccac 3444/4096 uxlate clean
Mwe 002f82d3 02f2a024 00555860          0 02f2808c 7908/8192 tcp_intercept_timer_process
<--- More --->
Lsi 0043a545 02fd48dc 00555860          0 02fd3954 3900/4096 route_process
Hsi 002e80f4 02fd596c 00555860         10 02fd4a04 3780/4096 PIX Garbage Collector
Hwe 00217101 02fdfa9c 00555860          0 02fdbb34 16048/16384 isakmp_time_keeper
Lsi 002e5e74 02ff905c 00555860          0 02ff80d4 3944/4096 perfmon
Mwe 0020e719 0302348c 00555860          0 03021514 7860/8192 IPsec timer handler
Hwe 0039a4db 03038054 00570980          0 0303610c 6880/8192 qos_metric_daemon
Mwe 00261395 03052b8c 00555860          0 0304ec24 15544/16384 IP Background
Lwe 002f8f4a 03105a1c 0056bc98          0 03104ba4 3704/4096 pix/trace
Lwe 002f9182 03106acc 0056c3c8          0 03105c54 3704/4096 pix/tconsole
H*  0011ee7e 0009ff2c 00555848        500 03115244 13148/16384 ci/console
Hwe 00433b3a 0311aa5c 005cac68         10 03119b24 3684/4096 lu_ctl
Csi 002f0fd3 0311bb2c 00555860          0 0311abd4 3432/4096 update_cpu_usage
Hwe 002dcba1 031bfac4 00534c00          0 031bbc3c 15884/16384 uauth_in
Hwe 003e6b5d 031c1bc4 00b69828          0 031bfcec 7896/8192 uauth_thread
Hwe 003fce0a 031c2d14 0054e788          0 031c1d9c 3960/4096 udp_timer
Hsi 001e2636 031c49d4 00555860          0 031c3a5c 3844/4096 557mcfix
Crd 001e25eb 031c5a94 00555cd8   10691530 031c4b0c 3728/4096 557poll
Lsi 001e26a5 031c6b34 00555860          0 031c5bbc 3716/4096 557timer
Cwe 001e4229 034c8c0c 007bfc58          0 034c6d14 7928/8192 pix/intf0
Mwe 003fcb7a 034c9d1c 00bb2450          0 034c8de4 3896/4096 riprx/0
<--- More --->
Msi 003a3999 034cae2c 00555860          0 034c9eb4 3888/4096 riptx/0
Cwe 001e4229 035ccfc4 0074a6e8          0 035cb0cc 7928/8192 pix/intf1
Mwe 003fcb7a 035ce0d4 00bb2408          0 035cd19c 3896/4096 riprx/1
Msi 003a3999 035cf1e4 00555860          0 035ce26c 3888/4096 riptx/1
Cwe 001e4229 036d137c 008351c8          0 036cf484 7928/8192 pix/intf2
Mwe 003fcb7a 036d248c 00bb23c0          0 036d1554 3896/4096 riprx/2
Msi 003a3999 036d359c 00555860          0 036d2624 3888/4096 riptx/2
Cwe 001e4229 037d5734 008aa738          0 037d383c 7928/8192 pix/intf3
Mwe 003fcb7a 037d6844 00bb2378          0 037d590c 3896/4096 riprx/3
Msi 003a3999 037d7954 00555860          0 037d69dc 3888/4096 riptx/3
Cwe 001eccfd 038d9b5c 00a0b360          0 038d7bf4 8040/8192 pix/intf4
Mwe 003fcb7a 038dabfc 00bb2330          0 038d9cc4 3896/4096 riprx/4
Msi 003a3999 038dbd0c 00555860          0 038dad94 3888/4096 riptx/4
Cwe 001eccfd 039ddf14 00a0b2b8          0 039dbfac 8040/8192 pix/intf5
Mwe 003fcb7a 039defb4 00bb22e8          0 039de07c 3896/4096 riprx/5
Msi 003a3999 039e00c4 00555860          0 039df14c 3888/4096 riptx/5
Hsi 00434921 039e22dc 00555860          0 039e1364 3800/4096 lu_xmit_timer
Hwe 00433665 039e337c 00551f38          0 039e2414 3900/4096 lu_rx
Hwe 001b0a3f 03acc48c 0055d4d8        450 03acb524 3292/4096 fover_thread
Hwe 0011f217 03acd1e4 00502c18          0 03acc53c 3204/4096 fover_rx
<--- More --->
Hwe 001b3791 03ace4cc 0055db5c          0 03acd554 3960/4096 fover_tx
Hwe 001b0c44 03acf4e4 0055db68          0 03ace56c 3960/4096 fover_rep
Lwe 001b0dfd 03ad050c 0055db70          0 03acf584 3976/4096 fover_lu_rep
Hwe 001b3d72 03ad4514 0055db78          0 03ad059c 16212/16384 fover_parse
Hwe 003e6df1 03b51e04 00b3ffb0          0 03b51b5c  284/1024 listen/http1
Hwe 003fcb7a 03b529b4 00bb2258          0 03b5200c 2356/4096 snmp
Hwe 003fcb7a 03b535d4 00bb22a0          0 03b5328c  840/1024 snmp_ex
Hwe 003e6df1 03b53a14 00b400a8          0 03b537cc  172/1024 listen/pfm
Hwe 003e6df1 03b542c4 00b401a0          0 03b53c7c 1196/2048 listen/telnet_1
Mwe 00370852 03b564a4 00555860          0 03b5452c 7640/8192 Crypto CA
------------------ show failover ------------------
Failover Off
Cable status: My side not connected
Reconnect timeout 0:00:00
Poll frequency 15 seconds
------------------ show traffic ------------------
<--- More --->
outside:
    received (in 11571.660 secs):
        0 packets    0 bytes
        0 pkts/sec    0 bytes/sec
    transmitted (in 11571.660 secs):
        0 packets    0 bytes
inside:
        0 packets    0 bytes
        480 packets    28800 bytes
        0 pkts/sec    2 bytes/sec
WAN:
        0 packets    0 bytes
        0 packets    0 bytes
<--- More --->
DMZ:
    received (in 11572.160 secs):
        0 packets    0 bytes
    transmitted (in 11572.160 secs):
        0 packets    0 bytes
intf4:
        0 packets    0 bytes
        0 packets    0 bytes
intf5:
        0 packets    0 bytes
<--- More --->
        0 packets    0 bytes
------------------ show perfmon ------------------
PERFMON STATS:    Current      Average
Xlates               0/s          0/s
Connections          0/s          0/s
TCP Conns            0/s          0/s
UDP Conns            0/s          0/s
URL Access           0/s          0/s
URL Server Req       0/s          0/s
TCP Fixup            0/s          0/s
TCPIntercept         0/s          0/s
HTTP Fixup           0/s          0/s
FTP Fixup            0/s          0/s
AAA Authen           0/s          0/s
AAA Author           0/s          0/s
AAA Account          0/s          0/s
<--- More --->
------------------ show running-config ------------------
: Saved
PIX Version 6.3(3)
interface ethernet0 100full
interface ethernet1 100full
interface ethernet2 100full
interface ethernet3 100full
interface ethernet4 auto shutdown
interface ethernet5 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 WAN security20
nameif ethernet3 DMZ security10
nameif ethernet4 intf4 security8
nameif ethernet5 intf5 security10
enable password ekYJs62QpGo3yhFR encrypted
passwd L3VazNrH9ZA721zj encrypted
<--- More --->
hostname FW-CORP
domain-name nlcindia.com
clock timezone IST 5 30
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 194.39.131.34 SAPinternational
name 194.117.106.129 SAPInter1
name 192.170.77.107 ISEE_server_GH
<--- More --->
name 59.145.145.85 srldc
name 202.71.156.134 accounts_site
name 202.71.128.85 icwai
name 164.100.194.13 ENVFOR.NIC.IN
name 61.246.52.130 srldc2
name 164.100.10.11 cisf_mail
name 220.227.184.157 NRYHRIDLYA
name 180.151.32.65 SRLDC
name 111.93.128.27 SRLDC2
name 111.93.128.28 SRLDC-3
name 212.95.126.13 OPENVASNVT
object-group service InetWebServerOutsidePorts tcp
  description Outside m/c can connect to these ports
  port-object eq 8080
  port-object eq 8085
  port-object eq www
  port-object eq https
object-group network WebServers
  network-object 172.16.164.68 255.255.255.255
  network-object 172.16.92.52 255.255.255.255
<--- More --->
  network-object 172.16.116.99 255.255.255.255
  network-object 172.16.24.75 255.255.255.255
  network-object 172.16.24.58 255.255.255.255
  network-object 172.16.28.51 255.255.255.255
  network-object 172.16.140.51 255.255.255.255
  network-object 172.16.49.50 255.255.255.255
  network-object 172.16.24.71 255.255.255.255
  network-object 172.16.24.80 255.255.255.255
object-group service Browsing-Download tcp
  description Protocols for Browsing & Downloading
  port-object eq www
  port-object eq ftp-data
  port-object eq ftp
  port-object range 9080 9080
object-group network netadmin
  network-object 172.16.26.1 255.255.255.255
  network-object 172.16.26.3 255.255.255.255
  network-object 172.16.24.134 255.255.255.255
object-group service InetWebServerRemoteMgmt tcp
<--- More --->
  description Services to remotely manage Internet Web Server
  group-object Browsing-Download
  port-object eq telnet
object-group network AMSDATA
  description To get AMS Data from WAN
  network-object 172.16.24.133 255.255.255.255
  network-object 172.16.24.129 255.255.255.255
object-group network WAN_ROUTERS
  description Routers in WAN
  network-object 172.16.232.1 255.255.255.255
  network-object 172.16.240.1 255.255.255.255
  network-object 172.16.9.21 255.255.255.255
  network-object 172.16.9.22 255.255.255.255
  network-object 172.16.248.1 255.255.255.255
  network-object 172.16.9.23 255.255.255.255
object-group network CR_WAN
  description Card Readers WAN
  network-object 172.16.233.13 255.255.255.255
  network-object 172.16.233.14 255.255.255.255
object-group service GH-TELE-PORTS tcp
<--- More --->
  description Ports needed for TeleMedicine
  port-object eq www
  port-object eq 1740
  port-object range 1715 1731
object-group network AMSPC_WAN
  network-object 172.16.233.1 255.255.255.255
  network-object 172.16.233.28 255.255.255.255
object-group service InetWebServerASRPorts tcp
  description Ports opened for ASR of SUN Server
  port-object eq 1691
  port-object eq 162
  port-object eq 6481
object-group network MMC_HOSTS
  description Servers in MMC
  network-object 172.16.104.65 255.255.255.255
  network-object 172.16.104.67 255.255.255.255
  network-object 172.16.104.89 255.255.255.255
access-list acl-in permit icmp any any
access-list acl-in permit tcp any host 172.16.8.51 eq www
<--- More --->
access-list acl-in permit tcp any host 172.16.8.51 eq 8080
access-list acl-in permit tcp any host 172.16.8.51 eq 8085
access-list acl-in permit tcp any host 172.16.8.51 eq https
access-list acl-in permit ip host 172.16.120.70 host ISEE_server_GH
access-list acl-in permit ip any host srldc
access-list acl-in permit ip host 172.16.104.66 host 172.16.8.51
access-list acl-in permit tcp host 172.16.24.56 any object-group Browsing-Download
access-list acl-in permit tcp host 172.16.24.56 host accounts_site eq 85
access-list acl-in permit tcp host 172.16.24.56 host icwai eq 85
access-list acl-in permit tcp host 172.16.24.56 host ENVFOR.NIC.IN eq 8080
access-list acl-in permit ip object-group netadmin any
access-list acl-in permit tcp host 172.16.24.80 host 172.16.8.51
access-list acl-in permit tcp host 172.16.24.56 any eq domain
access-list acl-in permit udp host 172.16.24.56 any eq domain
access-list acl-in permit tcp host 172.16.24.58 any eq domain
access-list acl-in permit udp host 172.16.24.58 any eq domain
access-list acl-in permit tcp host 172.16.26.4 host 172.16.8.51 object-group InetWebServerRemoteMgmt
access-list acl-in permit ip host 172.18.4.72 host 172.16.8.254
access-list acl-in permit ip any host 172.16.8.254
access-list acl-in permit tcp host 172.16.24.58 host 172.16.8.52 eq smtp
<--- More --->
access-list acl-in permit tcp host 172.16.24.58 host 172.16.8.52 eq 27
access-list acl-in permit tcp host 172.18.4.72 host SAPinternational eq 3299
access-list acl-in deny tcp host 172.18.4.72 eq 3200 host 172.16.8.254 eq 3200
access-list acl-in permit udp host 172.16.24.48 object-group WAN_ROUTERS eq snmp
access-list acl-in permit udp host 172.16.24.38 object-group WAN_ROUTERS eq snmp
access-list acl-in permit ip any host srldc2
access-list acl-in permit tcp any host cisf_mail eq 465
access-list acl-in permit tcp any host cisf_mail eq 995
access-list acl-in permit ip host 172.16.123.50 host NRYHRIDLYA
access-list acl-in permit ip any host SRLDC
access-list acl-in permit ip any host SRLDC2
access-list acl-in remark SRLDC-3
access-list acl-in permit ip any host SRLDC-3
access-list acl-in permit tcp host 172.16.24.48 host OPENVASNVT eq 873
access-list acl-in permit tcp object-group netadmin object-group CR_WAN eq www
access-list acl-in permit tcp host 172.16.34.106 object-group CR_WAN eq www
access-list acl-in permit tcp any host 172.16.8.52 eq 8080
access-list acl-in permit udp host 172.16.24.56 any eq snmp
access-list acl-in permit ip object-group AMSDATA host 172.16.241.1
access-list acl-in permit ip host 172.16.43.48 host 61.95.184.68
<--- More --->
access-list acl-in permit ip host 172.16.24.56 any
access-list acl-in permit ip host 172.16.43.38 host 121.246.243.230
access-list acl-in permit ip host 172.16.43.48 host 121.246.243.230
access-list acl-in permit ip host 172.16.43.48 host 124.124.238.154
access-list acl-in permit ip host 172.16.43.48 host 121.240.157.157
access-list acl-in permit ip host 172.16.24.122 host 172.16.8.52
access-list acl-in permit ip host 172.16.120.18 host 122.183.188.158
access-list acl-in permit ip host 172.16.26.1 host 172.16.242.8
access-list acl-in permit ip host 172.16.26.2 host 172.16.242.8
access-list acl-in permit ip host 172.16.106.107 host 172.16.8.72
access-list acl-in permit ip host 172.16.24.134 host 172.16.8.72
access-list acl-in permit ip host 172.16.106.107 host 172.16.8.71
access-list acl-in permit ip host 172.16.24.134 host 172.16.8.71
access-list acl-in permit ip host 172.16.24.123 host 172.16.8.71
access-list acl-in permit ip host 172.16.106.103 host 172.16.8.71
access-list acl-in permit ip host 172.16.106.103 host 172.16.8.72
access-list acl-in permit ip host 172.16.104.155 host 172.16.8.71
access-list acl-in permit ip host 172.16.104.155 host 172.16.8.72
access-list acl-in permit ip host 172.16.24.78 host 172.16.242.2
access-list acl-in permit ip host 172.16.106.107 host 172.16.8.51
<--- More --->
access-list acl-in permit ip host 172.16.28.142 host 67.215.240.250
access-list acl-in permit ip host 172.16.24.61 host 172.16.8.51
access-list acl-in permit ip host 172.16.24.61 host 172.16.8.71
access-list acl-in permit ip host 172.16.104.65 host 172.16.8.51
access-list acl-in permit ip host 172.16.120.18 host 122.183.217.16
access-list acl-in permit tcp object-group MMC_HOSTS host 172.16.8.51 object-group InetWebServerASRPorts
access-list acl-in permit tcp host 172.16.104.155 host 172.16.8.51 eq telnet
access-list acl-in permit tcp host 172.16.24.75 host 172.18.160.66 eq www
access-list acl-in permit tcp host 172.16.24.75 host 172.18.160.68 eq www
access-list acl-in deny ip any any log
access-list acl-out permit icmp any any
access-list acl-out permit tcp any host 210.212.241.68 object-group InetWebServerOutsidePorts
access-list acl-out permit tcp any host 210.212.241.70 eq 1194
access-list acl-out permit tcp any host 210.212.241.72 eq www
access-list acl-out permit ip host SAPinternational host 210.212.241.94
access-list acl-out permit ip host SAPInter1 host 210.212.241.94
access-list acl-out permit tcp any host 210.212.241.69 eq smtp
access-list acl-out deny tcp 41.0.0.0 255.0.0.0 host 210.212.241.70 eq www
access-list acl-out permit tcp any host 210.212.241.70 eq www
access-list acl-out permit tcp any host 210.212.241.89 object-group GH-TELE-PORTS
<--- More --->
access-list acl-out permit tcp any host 210.212.241.69 eq 8080
access-list acl-out deny ip any any log
access-list acl-WAN permit icmp any any
access-list acl-WAN permit tcp any host 172.16.24.91
access-list acl-WAN permit udp any host 172.16.24.56 eq domain
access-list acl-WAN permit tcp any host 172.16.24.56 eq 8080
access-list acl-WAN permit tcp any host 172.16.8.51 eq www
access-list acl-WAN permit tcp any host 172.16.24.74 eq www
access-list acl-WAN permit tcp any host 172.16.104.65 eq www
access-list acl-WAN permit tcp any host 172.16.104.65 eq 7779
access-list acl-WAN permit tcp any object-group WebServers eq www
access-list acl-WAN permit tcp any host 172.16.78.105 eq 9090
access-list acl-WAN permit tcp host 172.16.233.57 host 172.16.24.71 eq ftp
access-list acl-WAN permit tcp host 172.16.242.153 host 172.16.24.71 eq ftp
access-list acl-WAN permit tcp host 172.16.242.154 host 172.16.24.71 eq ftp
access-list acl-WAN permit ip host 172.16.241.1 host 172.16.24.73
access-list acl-WAN permit ip host 172.16.241.1 host 172.16.24.81
access-list acl-WAN permit tcp any host 172.16.24.37
access-list acl-WAN permit ip host 172.16.241.1 host 172.16.24.37
access-list acl-WAN permit tcp any host 172.16.24.42 eq 7778
<--- More --->
access-list acl-WAN permit tcp any host 172.16.24.42 eq www
access-list acl-WAN permit tcp any host 172.16.24.42 eq 8080
access-list acl-WAN permit tcp any host 172.16.24.43 eq 7778
access-list acl-WAN permit tcp any host 172.16.24.48 eq 8090
access-list acl-WAN permit ip host 172.16.233.1 host 172.16.24.129
access-list acl-WAN permit tcp any host 172.16.24.43 eq www
access-list acl-WAN permit tcp any host 172.16.24.43 eq 8080
access-list acl-WAN permit tcp any host 172.16.24.75 eq www
access-list acl-WAN permit tcp any host 172.16.24.76 eq www
access-list acl-WAN permit tcp any host 172.16.94.161 eq 8000
access-list acl-WAN permit tcp any host 172.18.4.75 eq 8000
access-list acl-WAN permit ip any host 172.16.241.244
access-list acl-WAN permit tcp any host 172.16.24.71 eq 8080
access-list acl-WAN permit ip host 172.16.250.108 host 172.16.24.48
access-list acl-WAN permit ip host 172.16.250.108 host 172.16.24.134
access-list acl-WAN permit ip 172.16.232.0 255.255.252.0 host 172.16.164.57
access-list acl-WAN permit ip host 172.16.9.22 host 172.16.24.59
access-list acl-WAN permit ip host 172.16.9.21 host 172.16.24.59
access-list acl-WAN permit ip any host 172.16.24.78
access-list acl-WAN permit tcp any host 172.16.24.56 eq domain log
<--- More --->
access-list acl-WAN permit ip host 172.16.9.21 host 172.16.24.211
access-list acl-WAN permit ip host 172.16.9.22 host 172.16.24.211
access-list acl-WAN permit tcp object-group CR_WAN host 172.16.24.47
access-list acl-WAN permit tcp object-group AMSPC_WAN host 172.16.24.47
access-list acl-WAN permit ip host 172.16.240.1 host 172.16.24.134
access-list acl-WAN permit ip host 172.16.9.22 host 172.16.24.134
access-list acl-WAN permit ip host 172.16.242.2 host 172.16.24.78
access-list acl-WAN permit tcp host 192.168.20.100 host 172.16.24.37 eq sqlnet
access-list acl-WAN permit tcp host 192.168.20.100 host 172.16.104.65 eq 1526
access-list acl-WAN deny ip any any log
access-list acl-DMZ permit icmp any any
access-list acl-DMZ permit tcp host 172.16.8.51 host 172.16.24.58 eq smtp
access-list acl-DMZ permit tcp host 172.16.8.51 host 172.16.24.51 eq 1500
access-list acl-DMZ permit tcp host 172.16.8.51 any eq 1581
access-list acl-DMZ permit ip host 172.16.8.51 host 172.16.24.80
access-list acl-DMZ permit tcp any host 172.16.24.56 eq domain
access-list acl-DMZ permit udp any host 172.16.24.56 eq domain
access-list acl-DMZ permit tcp host 172.16.8.52 host 172.16.24.58 eq smtp
access-list acl-DMZ permit tcp host 172.16.8.52 any object-group Browsing-Download
access-list acl-DMZ permit ip host 172.16.8.52 host 172.16.24.80
<--- More --->
access-list acl-DMZ permit ip host 172.16.8.254 host 172.18.4.72
access-list acl-DMZ permit ip host 172.16.8.254 host 172.18.4.75
access-list acl-DMZ permit ip host 172.16.8.254 host 172.16.94.161
access-list acl-DMZ permit ip host 172.16.8.254 host SAPinternational
access-list acl-DMZ permit ip host 172.16.8.254 host SAPInter1
access-list acl-DMZ permit ip host 172.16.8.52 host 172.16.24.78
access-list acl-DMZ permit tcp host 172.16.8.52 any eq smtp
access-list acl-DMZ permit tcp host 172.16.8.52 host 172.16.24.47 eq sqlnet
access-list acl-DMZ permit tcp host 172.16.8.51 host 198.232.168.156 object-group InetWebServerASRPorts
access-list acl-DMZ permit tcp host 172.16.8.51 host 198.232.168.156 eq https
access-list acl-DMZ deny ip any any log
pager lines 20
logging on
logging timestamp
logging standby
logging trap debugging
logging host inside 172.16.24.59
mtu outside 1500
mtu inside 1500
mtu WAN 1500
<--- More --->
mtu DMZ 1500
mtu intf4 1500
mtu intf5 1500
ip address outside 210.212.241.66 255.255.255.224
ip address inside 172.16.24.3 255.255.252.0
ip address WAN 172.16.9.1 255.255.255.0
ip address DMZ 172.16.8.1 255.255.255.0
no ip address intf4
no ip address intf5
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 210.212.241.67
failover ip address inside 172.16.24.4
failover ip address WAN 172.16.9.2
failover ip address DMZ 172.16.8.2
no failover ip address intf4
no failover ip address intf5
<--- More --->
pdm location 172.16.120.18 255.255.255.255 inside
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 210.212.241.71 172.16.24.18 netmask 255.255.255.255 0 0
static (DMZ,outside) 210.212.241.68 172.16.8.51 netmask 255.255.255.255 0 0
static (DMZ,outside) 210.212.241.69 172.16.8.52 netmask 255.255.255.255 0 0
static (DMZ,outside) 210.212.241.94 172.16.8.254 netmask 255.255.255.255 0 0
static (inside,outside) 210.212.241.70 172.16.24.58 netmask 255.255.255.255 0 0
static (inside,outside) 210.212.241.72 172.16.24.80 netmask 255.255.255.255 0 0
static (inside,DMZ) 172.16.0.0 172.16.0.0 netmask 255.240.0.0 0 0
static (inside,outside) 210.212.241.73 172.16.104.65 netmask 255.255.255.255 0 0
static (inside,WAN) 172.16.0.0 172.16.0.0 netmask 255.240.0.0 0 0
static (inside,outside) 210.212.241.89 172.16.120.18 netmask 255.255.255.255 0 0
access-group acl-out in interface outside
access-group acl-in in interface inside
access-group acl-WAN in interface WAN
access-group acl-DMZ in interface DMZ
route outside 0.0.0.0 0.0.0.0 210.212.241.65 1
<--- More --->
route inside 172.16.0.0 255.240.0.0 172.16.24.1 1
route WAN 172.16.232.0 255.255.252.0 172.16.9.21 1
route WAN 172.16.240.0 255.255.252.0 172.16.9.22 1
route WAN 172.16.248.0 255.255.252.0 172.16.9.23 1
route WAN 172.18.160.0 255.255.255.0 172.16.9.22 1
route WAN 192.168.20.0 255.255.255.0 172.16.9.22 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 172.16.24.134 255.255.255.255 inside
snmp-server host inside 172.16.24.48
no snmp-server location
no snmp-server contact
snmp-server community nlcwan
snmp-server enable traps
<--- More --->
floodguard enable
telnet 172.16.24.134 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:d5f1e5f299b82f169072858717c96f45
: end
FW-CORP#
1127
