not able to reach ASA ouside nat ip from inside
Hi..
I have a ASA 5525 ver 9.1(2). I have a inside interface 10.110.10.0/24 and outside network 115.112.94.0/27. I have natted a inside server with ip 115.112.94.10 and when trying to reach this public ip from inside machine, i can not reach this public ip.
I have disabled anti spoofing and enabled same security permit traffic inter and intra interface, also had open ACL but still dont work.
Pls help what could be issue.
Hi , Could you please share
Hi ,
 Could you please share me your ASA config ?? or NAT config
Sandy
  NAT config..object network
 NAT config..
object network obj-10.110.10.112
 nat (inside,outside) static 115.112.94.10
Interface                Name                   IP address      Subnet mask     Method
GigabitEthernet0/0       outside                115.112.94.2   255.255.255.224   manual
GigabitEthernet0/1       inside                 10.110.10.1   255.255.255.0   CONFIG
This ip(115.112.94.10) is reachable from public network. But not from behind firewall.
Hi Anukalp add a (inside
Hi Anukalp
add a (inside,inside) to make this work
you are trying to do a U-turn here,
TRY ADDING THE FOLLOWING:
 nat (inside,inside) static 115.112.94.10
Cheers
Naveen
Hope it helps Cheers, Naveen Please Rate Helpful posts.
Hi. Should i add above nat
Hi.
 Should i add above nat statement along with which i shared above, also let me know if it does not cause any other issue because this is server and it is in production.
Also let me know if any ports are also required to allow. I already had allowed all required ports from outside.
Hi  Add below command this
 Add below command this will not cause any issue for traffic , this configuration ensures NATing for inside to inside Access .
object network Public_Server
host 115.112.94.10
nat (inside,inside) source dynamic any interface destination static Public_Server obj-10.110.10.112
same-security-traffic permit intra-interface
Sandy
Thanks Santosh, i have a
Thanks Santosh, i have a guest network on firewall too and guest network can connect to this server through public ip only so any other nat rule do i need to place for this also.
GigabitEthernet0/2 guest 192.168.1.1 255.255.255.0 CONFIG
Hi , This NAT is applicable ,
Hi ,
 This NAT is applicable , when you are connecting from inside segment 10.110.10.0/24 . Not for Guest segment .
For Guest Segment server must be accessible with public IP address .
Sandy
 Hi Sandy.. i need to get
Hi Sandy.. i need to get this access from guest network, this guest network is like inside network but it has no connectivity to inside(denied by ACL), aslo users connecting on guest network gets ip of same pool configured on firewall guest interface. guest network is allowed only for internet traffic and natted with one of firewall outside interface ip pool. It can only communicate with server public ip.
Is it not possible to reach public ip of server from guest network.
Someone tell me if this
Someone tell me if this poosible to access natted server ip from guest network.
Pls help.
It should be work from Guest
It should be work from Guest Network . You should able to access it via Public IP address without any issue.
Sandy
Hi Sandy.. It is not working,
Hi Sandy.. It is not working, guest netowork is also dynamic pat with a ip of outside network pool and this inside server is too static nat   with a ip of outside network pool. Where is it getting blocked. Should there be no commnication in this scenario.
Hi , Can you share me packet
Hi ,
 Can you share me packet tracer output running from your DMZ interface towards Public IP address .
Else open a webex session to trouble fix on this .
Sandy
hi...pls see below logs Phase
hi...
pls see below logs
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
 Forward Flow based lookup yields rule:
 in  id=0x7fff33eab610, priority=1, domain=permit, deny=false
        hits=222687464, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0100.0000.0000
        input_ifc=wireless, output_ifc=any
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   115.114.94.0   255.255.255.224   outside
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group WIFI in interface wireless
access-list WIFI extended permit ip 192.168.1.0 255.255.255.0 any Additional Information:
 in  id=0x7fff349c2950, priority=13, domain=permit, deny=false
        hits=4244997, user_data=0x7fff2c4810c0, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
        src ip/id=192.168.200.0, mask=255.255.255.0, port=0, tag=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0, dscp=0x0
Phase: 4
Type: NAT
Subtype:
Result: ALLOW
Config:
object network obj-192.168.1.0
 nat (wireless,outside) dynamic 115.114.94.14 Additional Information:
Dynamic translate 192.168.1.144/0 to 115.114.94.14/65296  Forward Flow based lookup yields rule:
 in  id=0x7fff34e13cf0, priority=6, domain=nat, deny=false
        hits=625308, user_data=0x7fff35a33c30, cs_id=0x0, flags=0x0, protocol=0
        src ip/id=192.168.1.218, mask=255.255.255.192, port=0, tag=0
        input_ifc=wireless, output_ifc=outside
Phase: 5
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
 in  id=0x7fff32fc1830, priority=0, domain=nat-per-session, deny=true
        hits=73239394, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0
        input_ifc=any, output_ifc=any
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0x7fff34b458d0, priority=0, domain=inspect-ip-options, deny=true
        hits=4297048, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
 match default-inspection-traffic
policy-map global_policy
 class inspection_default
  inspect icmp
service-policy global_policy global
 in  id=0x7fff352fad60, priority=70, domain=inspect-icmp, deny=false
        hits=10146, user_data=0x7fff35771490, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
        src ip/id=0.0.0.0, mask=0.0.0.0, icmp-type=0, tag=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, icmp-code=0, tag=0, dscp=0x0
Phase: 8
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
 in  id=0x7fff34b45200, priority=66, domain=inspect-icmp-error, deny=false
        hits=19798, user_data=0x7fff33b9ea50, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 9
Type:
Subtype:
Result: ALLOW
Config:
 in  id=0x7fff36dd2f10, priority=18, domain=flow-export, deny=false
        hits=1475363, user_data=0x7fff3553ca30, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 10
Type: USER-STATISTICS
Subtype: user-statistics
Result: ALLOW
Config:
 out id=0x7fff3775d290, priority=0, domain=user-statistics, deny=false
        hits=56046448, user_data=0x7fff34f8ffa0, cs_id=0x0, reverse, flags=0x0, protocol=0
        input_ifc=any, output_ifc=outside
Phase: 11
Type: NAT
Result: ALLOW
Config:
 Reverse Flow based lookup yields rule:
        hits=73239396, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 12
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0x7fff34af96a0, priority=0, domain=inspect-ip-options, deny=true
        hits=128152752, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
        input_ifc=outside, output_ifc=any
Phase: 13
Result: ALLOW
Config:
 out id=0x7fff3775d650, priority=0, domain=user-statistics, deny=false
        hits=884040, user_data=0x7fff34f8ffa0, cs_id=0x0, reverse, flags=0x0, protocol=0
        input_ifc=any, output_ifc=wireless
Phase: 14
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 143923582, packet dispatched to next module Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_inspect_icmp
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_tracer_drop
snp_fp_translate
snp_fp_inspect_icmp
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
input-interface: wireless
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
How can we connect outside
How can we connect outside address from inside ...those r for outsiders only right ...insiders have inside address only to use.
 Hi , Apply below
Hi ,
 Apply below commands
host 115.112.94.10
! existing comand on your ASA you can ignore below object
host 10.110.10.112
Sandy
89
